Sewing grass
/ Sewing grass #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Trying to extend yard into area where I cleared out some trees (mostly pine) Been trying to sew grass and it never seems to really catch. The soil here seems to be primarily clay'ish, so I've been bringing soil over from other side of farm where I found a nice pocket of "black dirt" (probably an area of sediment eons ago... this "topsoil" layer is probably 5 or 6 feet deep before turning into clay)
Might bear to mention, the area this "topsoil" is coming from was ALSO timbered for pine trees at same time my side yard was.
I understand pine trees acidify the soil?
Don't really care if that's true or not, but if it's a factor, what might I put on soil to help prepare it for my current attempt at sewing grass?
Worked it all up last night with boxblade, going to bring couple more bucket loads over & try to finalize the "shape" we want then fertilize/sew..
What might I use to help? The entire yard has grass but it's rather cobby looking, nothing "lawnish" that you see on well manicured houses. I have 1/2 a mind to redo the entire yard after having 10 dump trucks bring in "real" dirt /forums/images/graemlins/grin.gif
Richard
/ Sewing grass #2
Richard,
I believe you are right on the acidity. Around here we would use lime to get rid of the acid's. You also may want to talk to some people in your area about the fertilizer your using also with the lime.
As far as sewing the grass I did a bunch of it myself and it worked great. I just used my broadcast spreeder to spreed the seed around and then used a drag to drag it in. Point being to get the seed to be buried about an 1" in the ground. You want to do this in a cooler time of the year. This way you don't have to keep it as moist.
murph
/ Sewing grass
cool time eh? like now lol. My goal (live on slope) is to get it to root some prior to rain so my yard doesn't wash away (again) /forums/images/graemlins/frown.gif
/ Sewing grass #4
Re: Sowing grass
Sure got my curiosity up when you said you were "sewing" grass. /forums/images/graemlins/grin.gif
I have some of the same dilemna's with what to do given poor soil, and am thinking I will try punching holes in it to aerate it. After 35 years of mowing, maybe it needs a breather.
/ Sewing grass #5
See if you can get a soil test kit at a local garden shop. That is probably the only way to make sure the soil is OK. They are pretty inexpensive, alot less than wasted grass seed /forums/images/graemlins/smile.gif
As for a new lawn, I've had good success with preparing the seed bed, sowing the seeds, covering with lose soil and rolling it to make sure the seeds have soil contact. Plant it too deep or too shallow and it won't work. What's the magic depth? 1/4 to 1/2 inch worked for me, your results may vary. Then water, water, water until it sprouts and then water it some more until it gets high enough to cut. Bag the clippings until the 4th cut. After that, treat it like a normal lawn. Only water it once or twice a week, deeply. If you give it short, shallow drinks, the roots will never develop to reach down for water, then you'll be suceptible to drought.
/ Sewing grass
How bout that.. soil test kit.. just called the local box, and for $3.20, I can get a test kit....
Guess what I'm doing today presuming it doesnt' rain /forums/images/graemlins/grin.gif
/ Sewing grass #7
Are you just sprikling it out there? You need to prepare the soil first. Grass won't grow in clumps of dirt very well. You really should have your soil worked down pretty fine. Then use a drill. If you don't have a drill broadcast it and harrow it. Also it's going to need lots of water to get est. If you can't get water to it pray for rain and plant during the rainy season.
As has been mentioned get a good soil sample. That will tell you where you need to be there. Also I would fertilize a week or less before I plant the seed.
/ Sewing grass
preliminary update...
Tested ph and it showed 8 (?) lol
Am currently letting my soil/water mixture settle for rest of sample.
I'd NEVER thought about fertilizing PRIOR to seeding, I'd done it afterwards. Thanks for the heads up.
Will post other results after dinner
SOMEONE on this board is absolutely starving now. /forums/images/graemlins/shocked.gif
Richard
/ Sewing grass
Ok, stomach be darned and all with it's growling at me for sustinence....
Couldn't wait on results, so if I read this scale correctly
PH = 8.0 Alkaline
Nitrogen = very low (or lower than that actually)
Phosphorous = very low or below.. actually, the strip shows light bluish and the vile looks more color of lemonaid.. lol not blue at all
Potash = I'd guess between low and very low
Hmm..seems all I have is black organic material? /forums/images/graemlins/tongue.gif
If this tidbit helps, (washing acid out?) the pine trees were harvested maybe 2 years ago, possibly 2 1/2.
Anyway, that's results of my test as best I can tell. I called the test kit company and they close at 5:30 eastern, so I missed them of course.
Thanks for any thoughts.
Richard
/ Sewing grass #10
<font color="blue"> just called the local box, and for $3.20, I can get a test kit.... </font>
Pretty cool, huh? /forums/images/graemlins/cool.gif
At least it can get you in the ballpark before you start. good luck. Be sure to take before, during and after pictures for yourself(and us too /forums/images/graemlins/tongue.gif)
/ Sewing grass
I've been overruled
Wife & father in law say
PH = 7.0 Neutral
Nitrogen = very low
Phosphorous = low
Potash = very low
if they say it, it must be true /forums/images/graemlins/crazy.gif
/ Sewing grass #12
So now you need to figure out how much fertilizer to bring up the numbers. Your local county extension agent should be able to help you with that. Your garden center might, but the county folks usually have more knowledge.
/ Sewing grass #13
Find a farming coop in your area. I would get an official soil test from them. They will then be able to recommend what to put on your soil. Don't even waste your time trying to seed with that poor of soil. It's no wonder nothing was growing. /forums/images/graemlins/tongue.gif
/ Sewing grass #14
Richard,
You may find that you have to fertilize a couple of weeks before you seed. Then you may have to fertilize every 6 weeks. I have some land that I sowed grass seed and it gets very brown about every 4 or 5 weeks. I just have to keep putting on the fertilizer.
murph
/ Sewing grass #15
According to sewing machine One nice thing about such a simple and adaptive technique, is that you can make these bags in any size to suit your needs. Are you someone who buys a lot of celery? Make yourself a long and slender bag specifically for those watery stalks. Do you need a constant supply of large and leafy kale? An extra large mesh bag should do the trick. You are the master of your own grocery shopping destiny!
Solid input to an 18 year old thread.....Thanks
/ Sewing grass #16
It kind of depends upon what type grass you are sewing. My soil is jet black and quite acid. My only trees - Ponderosa pine.
Local Ag extension service recommended I sew with native field grass. It has become acclimated to the acid soil. So ...... that's what I got and it has established very well.
Normal lawn grass would require lots of lime and lime addition almost every year.
/ Sewing grass #17
Huh? How did this 18 YO thread about "sewing grass" (AKA sowing grass seed) suddenly come back as a thread about sewing machines? :confused: Enquiring minds want to know!!!
/ Sewing grass #18
I wonder if we should pre-treat for echo before sewing our grass.
/ Sewing grass #20
I think your county agent's office might be helpful in this situation.
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2015 International ProStar T/A Day Cab Truck Tractor (A61573)
2015 International...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
