Snow Setting up my snow thrower an have a question?
   / Setting up my snow thrower an have a question? #1
Inkmann
Western MA
John Deere 2305
These shoes don't look like they are setup correctly.
What do you think?
   / Setting up my snow thrower an have a question? #2
They look like they are mounted in the wrong holes. The shoes should be relatively level when the blower is lowered.
   / Setting up my snow thrower an have a question? #3
Is this new? I hope not as the shoe should fit flat on the ground.
   / Setting up my snow thrower an have a question? #4
It looks to me that the shoe needs to be moved back a hole. Then I believe it would be close to level.
That's exactly what I was thinking.
The previous owner had it set up that way. It was that way when I got it.
Are those shoes gonna mark up my driveway? I just sealed it up nice on October.
   / Setting up my snow thrower an have a question? #6
Yep, you need Robalon shoes
Found them, kinda expensive!
   / Setting up my snow thrower an have a question? #8
This is correct. They should also go on the inside, not outside.
When I set the depth on my shoes I put it on a flat surface with an 1/8 inch spacer under the cutter bar and the shoes flat on the surface.
1994 21ft. Aquasport Division Boat with 24ft. Continental T/A Boat Trailer (A55758)
1994 21ft...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
16FT box truck (A53422)
16FT box truck...
2006 GMC W5500 Dovetail Flatbed Truck (A55788)
2006 GMC W5500...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
