Snow Setting up my snow thrower an have a question?
   / Setting up my snow thrower an have a question? #1
Inkmann
Member
Western MA
John Deere 2305
These shoes don't look like they are setup correctly.
What do you think?
   / Setting up my snow thrower an have a question? #2
They look like they are mounted in the wrong holes. The shoes should be relatively level when the blower is lowered.
   / Setting up my snow thrower an have a question? #3
Is this new? I hope not as the shoe should fit flat on the ground.
   / Setting up my snow thrower an have a question? #4
It looks to me that the shoe needs to be moved back a hole. Then I believe it would be close to level.
That's exactly what I was thinking.
The previous owner had it set up that way. It was that way when I got it.
Are those shoes gonna mark up my driveway? I just sealed it up nice on October.
   / Setting up my snow thrower an have a question? #6
Yep, you need Robalon shoes
Found them, kinda expensive!
   / Setting up my snow thrower an have a question? #8
This is correct. They should also go on the inside, not outside.
When I set the depth on my shoes I put it on a flat surface with an 1/8 inch spacer under the cutter bar and the shoes flat on the surface.
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55301)
JOHN DEERE ROW...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
1990 KME (A53424)
1990 KME (A53424)
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A55788)
2012 Mack CXU613...
