setting trusses with only 2?
/ setting trusses with only 2? #61
Sounds just like I do it. Splicing on a truss is just plain a pain and not the best way.
Egon
Wait a minute guys, you mean i can just let the lumber run and scab the 2x4's together wherever they need to be joined, even if its between the trusses? kinda like plywood sheathing a roof and connecting the sheets with those little connector? I wish i would have known that, i was thinking about that today because i was tired of cutting and waisting so much lumber just to get them to break on the trusses..so how do they need to be scabbed together, just use a short peice of 2x4 underneath the spot where the 2x4's will be joined together, how long should the scab board be and what type and how long do the scres need to be? Is it still good and strong like this, remember, the trusses are on 4' centers..? This sounds like a plan!! Let me know the details! /forums/images/graemlins/laugh.gif
/ setting trusses with only 2? #63
"so how do they need to be scabbed together, just use a short peice of 2x4 underneath the spot where the 2x4's will be joined together, how long should the scab board be and what type and how long do the scres need to be?"
Chad,
If using 2x4's I would use a 2' scab underneath and put two 3" deck screws on each side of the joint, one near the joint and the second near the end of the scab. Predrill the holes through your purlin so the screws hold tight or use a c-clamp to hold them tight and just set the screws that way.
/ setting trusses with only 2? #64
I am going to have to disagree that this can be equal to hitting a truss. Standing on this joint you are saying that the screws are going to be as strong as gravity on the truss, I wouldn't trust the screws over the life of the building.Looking up from below it is going to look scabbed which makes it look like corners were cut elsewhere. If you have a 2ft overhang on the gable that you start with then start with a 10 ftr and the end will hit the 2nd truss change to 16 or 12 and you will continue hitting the trusses. starting with 10 then 14 then 6 then continuing up the slope in order guarantees joints alternating on trusses and no slowdown to cut scabs clamp or drilling screws. Plus it will end up looking like it is right.
is it safe to put your weight on these joints scabbed together? also, do i screw the screw from the purlin into the scab board, or from the scabboard into the purlin?
/ setting trusses with only 2? #67
Generally you could put your weight on the 2x4 two feet from the truss without any "scab" support due to the stiffness of the 2x4. It may give more, but shouldn't break unless it has a big knot. The two screws on either side of the joint spread the stresses out more and provide a lot of strength. True, it's probably not as strong as a solid timber, but over a four foot span I have found it to be plenty strong enough. I prefer to put the screw through the purlin into the scab board, because occasionally the screw will drive until the head is below the surface and with 3" screws could result in te point of the screw rubbing your metal roofing if driven through the scab upward into the purlin.
We aren't concerned with any snow load in this area, and I've gone to using 1x4 for purlin, splicing as above. This has provided plenty of support, but you have to watch for knotty places when you step with trusses on 4' centers.
well the only problem with doing it this way is that i will have to hope the breaks are exactly in the middle ofthe trusses, most of them seem to be about 3/4 between them..
/ setting trusses with only 2? #69
My brother, son and I put these 30' x 2' steel trusses into place with out power equipment. Not the safest way to do it but we got it done.
http://community.webshots.com/photo/43399132/43400790VmJCWL
1) We welded a pin vertically at the top of the pole and passed a rope around it.
2) We put two extension ladders up on either side of the first pole and wired them together at the top.
3) A rope was passed around the pin and down to the truss. While two of us lifted the truss a foot or so at a time my son would take slack out of the rope and hold the truss in place while we rested and climbed the next rung of the ladders.
Don't flame me. I don't recommend doing this. A front end loader or forklift would be the correct way to do this job.
TBAR
The ting i really hate about splicing on a truss is that the truss is only 1 1/2" wide as it is, so when splicing, your nailing each purlin right on the very edge of the truss, with 4 nails at that, seems like its not going to be secured that well because of the nails driving in so close to the edge of the purlins and the truss, i hated it yesterday each time i did a splice like this, makes me cringe..
/ setting trusses with only 2? #71
Mowpower
As long as you step the purlin joints to different trusses as others have stated ,you'll be fine . John
ok, next thing, where is the cheapest place to buy colored metal roofing? I have priced lowes, home depot, and 84 lumber and all are 1.62- 1.70 per linear foot for painted metal, you guys here told me to go to a truss manufacturer to get the trusses cheaper, and i did, so i figured i better ask about the metal roofing, figured you all might know where to get it cheaper..im looking for it in brown.
/ setting trusses with only 2? #73
That sure is a lot of work just to put another roof over the shed.
Come alongs work well too.
Egon
/ setting trusses with only 2? #74
Do a web search for metal roofing . I suspect you'll find prices a bit cheaper than Lowes/HD . But you'll also be paying shipping charges . Personally we use Holmes lumber out of Ohio . But, I have no idea of how far you are from them .
While the price of metal roofing seems high initially . You have to remember you're not running sheathing ,tar paper and shingles . That might be a bit cheaper depending on your choice of materials . But you need to figure that your time is worth something as well . John
/ setting trusses with only 2? #75
"well the only problem with doing it this way is that i will have to hope the breaks are exactly in the middle ofthe trusses, most of them seem to be about 3/4 between them.. "
Two feet length for the scab pieces is an approximation. If you are four or five inches past the truss with the purlin it would make sense to just cut the purlin at the truss and nail there. If you have seven or eight inches to a foot of purlin past the truss use a scab. As far as where to buy the metal, try looking in your yellow pages under roofing supplies or ask around your community. There is probably a company fairly near you that specializes in metal roofing products, where you can have the metal cut to the length you want. The box stores are generally more expensive and only carry precut lengths. Hex-head screws are more expensive than nails, but they will hold better and won't loosen from the sun as nails will. I wouldn't use anything else.
/ setting trusses with only 2? #76
Your profile doesn't give a clue where you live so it will be hard for anyone to give you info on good prices.
I bought $1600 worth yesterday for $1.45/linear foot for 29 gauge painted galvalume from a local place that builds metal buildings, portable buildings and carports. I called all over this part of the state and they were the cheapest. The other places were in that ballpark also.
I've enjoyed following your post as I am about to start on my shop if this rain will ever stop.
TBone
They told me that the prices from their supplier were going up this week - anything that was ordered after 4:00 pm on Wednesday would be higher - didn't say how much. My son works for a steel fabricater and they ordered 16 loads of steel last week to beat the price increase.
/ setting trusses with only 2? #77
Tbone,
If you already took delivery of the painted galvalume you should know to try to keep it dry. If you leave it out in the weather where it can get wet while stacked it will discolor and possibly damage it. Looking forward to seeing your progress reports on the new shop.
Im in middle tennessee, 40 miles south of nashville.
/ setting trusses with only 2? #79
Yes, Glenn I was told not to let it get wet while stacked. I haven't broke the news to the wife yet about parking her car outside so I can keep my metal dry. /forums/images/graemlins/shocked.gif
I was going to start next week but it has rained here every other day for weeks and I haven't even bought my lumber or insulation. I'll try to post some pictures when I get started.
TBone
/ setting trusses with only 2? #80
I just noticed you are from MS. I lived most of my life in Lawrence County, and got transplanted over here to Monroe. What part of the state are you in?
ATS Mini Excavator (A66285)
ATS Mini Excavator...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
