setting a fusion valve relief and testing system pressure
   / setting a fusion valve relief and testing system pressure
JJ the manual seems to have originally been written in french for people who already know how to set these up, then translated- in short not too detailed. The reason i thought the pressure might not have been set is that the motor appeared to have been in the original packaging from the manufacturer and the paint on the adjustment screws is pristine.
i would have tested the pressure today but the gauge i ordered has 1/4 npt not 3/8 so i need a adapter.
i got things working but have a slight leak at the joint between motor and the #10 boss o-ring fitting. I am a bit confused as to torque to use as the motor instructions state a max of 8 in-lbs and the on-line numbers i find are circa 50 ft-lbs -- a huge difference.
i guess a phone call is in my future
ok it seems my reading comprehension sucks- did not get enough sleep last. the fine print indicates what i thought was in- lb was actually daNM and that works out to 52 ft-lbs so i can use more force- off i go
and now leak is gone-next time reading glasses first time
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
2021 New Holland C327 Compact Track Loader (A51039)
2021 New Holland...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
