setting a fusion valve relief and testing system pressure
   / setting a fusion valve relief and testing system pressure
JJ the manual seems to have originally been written in french for people who already know how to set these up, then translated- in short not too detailed. The reason i thought the pressure might not have been set is that the motor appeared to have been in the original packaging from the manufacturer and the paint on the adjustment screws is pristine.
i would have tested the pressure today but the gauge i ordered has 1/4 npt not 3/8 so i need a adapter.
i got things working but have a slight leak at the joint between motor and the #10 boss o-ring fitting. I am a bit confused as to torque to use as the motor instructions state a max of 8 in-lbs and the on-line numbers i find are circa 50 ft-lbs -- a huge difference.
i guess a phone call is in my future
ok it seems my reading comprehension sucks- did not get enough sleep last. the fine print indicates what i thought was in- lb was actually daNM and that works out to 52 ft-lbs so i can use more force- off i go
and now leak is gone-next time reading glasses first time
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
