setting a fusion valve relief and testing system pressure
   / setting a fusion valve relief and testing system pressure
JJ the manual seems to have originally been written in french for people who already know how to set these up, then translated- in short not too detailed. The reason i thought the pressure might not have been set is that the motor appeared to have been in the original packaging from the manufacturer and the paint on the adjustment screws is pristine.
i would have tested the pressure today but the gauge i ordered has 1/4 npt not 3/8 so i need a adapter.
i got things working but have a slight leak at the joint between motor and the #10 boss o-ring fitting. I am a bit confused as to torque to use as the motor instructions state a max of 8 in-lbs and the on-line numbers i find are circa 50 ft-lbs -- a huge difference.
i guess a phone call is in my future
ok it seems my reading comprehension sucks- did not get enough sleep last. the fine print indicates what i thought was in- lb was actually daNM and that works out to 52 ft-lbs so i can use more force- off i go
and now leak is gone-next time reading glasses first time
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A51222)
2019 FREIGHTLINER...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
