Septic System - Infiltrator System
/ Septic System - Infiltrator System #61
following -- in my situation is that the county is footing the bill to install a replacement system. their engineer is figuring on a 1275 tank for 6 bedroom but only 5 people with pump/filter and chambers lines as well.
Wow, that seems like a small tank for a 6 bedroom. In my area a 6 bedroom home would require 2,000 - 2,500 GAL tank.
1,275 Gallons with 5 people in the home is a small tank. It will reach capacity pretty quickly and require pumping every 2-3 years. I would upsize to a 2,000 GAL tank. We are talking maybe a few hundred dollars in costs.
/ Septic System - Infiltrator System #63
I am going with the Mutual Industries WF200 Polyethylene Woven Geotextile Fabric. It looks like heavy duty fabric.
For filter fabric, you really should be using the non-woven. The woven stuff is more for under roadbeds to keep the gravel from sinking down into the soil.
I've seen the Mutual stuff all over the 'Net, but one thing bothers me - I can't find the weight of it anywhere. It's standard to specify ounces per square yard, but Mutual doesn't. Check their spec sheet.
The woven fabric is better that way. I don't want gravel or soil sinking into the chambers. The non-woven is the cheap landscape stuff that falls apart.
Not sure about the ounces. It's pretty heavy duty fabric according to the tests and specs it lists. Most big box store stuff doesn't even have specs.
/ Septic System - Infiltrator System #65
The ounces are what matters. If a manufacturer will not state the weight, be very very suspicious. That's like a tractor manufacturer refusing to state the horsepower.
You are thinking of the cheapo stuff you get at the home store. I'm talking about what highway departments and professionals use. I'm currently putting in 1000' of french drain to solve a problem on my property, and I've researched this extensively. I'm tying in to an existing french drain that was recently installed by a contractor on a neighbor's property. The shady contractor used the cheapo landscape fabric you are talking about. It's junk.
I'm using the 4 oz non-woven fabric that is spec'd by the Virginia DOT for such work. Looking at them side by side, mine is about 15 or 20 times thicker. It's like a decent blanket you'd put on your bed. It would keep you warm. Probably close to 1/8" thick. It is the CORRECT stuff for your application.
This is the stuff I'm using:
Non Woven Filter Fabric
See here for a decent competitor's citation of the VDOT specs. Note that this is specifically called, "filter fabric".
Virginia - Geotextiles & DOT Specifications - US Fabrics
US 12NW - Nonwoven Geotextile - US Fabrics
On the concrete D-Box, the box is level but I noticed that one distribution pipe is a tad lower than the other 3 pipes so during the test run that one pipe got more water flow.
I noticed that some people install the Roto-Flow or similar covers that fine tune distribution. Are those a good idea if I am experiencing the above?
If the COUNTY is paying for it, that might explain WHY they only want to install a 1275 gallon tank for a 6 bedroom home. They are cutting costs at your expense.
/ Septic System - Infiltrator System #69
That's the stuff you want. They call it "filter cloth".
But check around you carefully. You might find a business that sells that stuff to contractors, and get it at a cheaper price. That's what I did. It's working really well for me to be able to run grab whatever I need locally.
Check your local phone book (I know, who uses a paper phone book anymore? :D) and search the 'Net.
/ Septic System - Infiltrator System #70
Yep.
Maybe offer to pay the difference to get the larger tank?
Kubota SVL97-2 (A60462)
Kubota SVL97-2...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
High Accuracy Meter Fuel Pump (A61166)
High Accuracy...
40' CONTAINER (A52706)
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
