New septic and leach line: Infiltrators vs pipe /poly tank vs concrete?
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #21
Would you feel comfortable driving over that in say a tractor (not the tank)?
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #22
The least ground compaction the better but realistically if it’s dry enough not to make ruts it’s alright.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #23
I drive over my infiltrators with an 8,000# tractor, but keep away from the tank. If the tractor is making ruts, i stay off the yard competely.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #24
a lot of places require a stamped engineer drawing for a new septic system, soil perc tests, excavation inspections, plumbing inspections and final inspections. Our new system cost more than my 2015 pickup truck.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #25
Some of the new dosing systems required around lakes here in idaho can top $40k
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #26
There’s no way I’d spend $2500 to have a system “engineered” I’d take that money and overdo it by double if it would make you feel better. Locally the state office provides a sheet of the minimum requirements they deem necessary for the soil conditions and bedrooms.
If that’s an option-many counties require that the septic design be done by a licensed septic engineer (most of the more populated counties in my state require this). Some counties specify install by an approved septic installer as well-in my case, my excavator buddy is an approved installer, so he supervised me during the excavation and such and then initialed the ‘as built’ prior to the counties final inspection and buy off of the installed system.
There痴 no way I壇 spend $2500 to have a system 兎ngineered I壇 take that money and overdo it by double if it would make you feel better. Locally the state office provides a sheet of the minimum requirements they deem necessary for the soil conditions and bedrooms.
4750, I have to agree with you. After being told that I should have it engineered, I checked out just what that meant. I learned that 'engineering' is something that is required only in very unusual or tricky installations - those where a typical installation may not be possible. Then I talked to another installer who said that engineering my system was not needed in my county. However, apparently it may be required in an adjoining county. There is always more to learn.
2025 7ft 10 Drawer 2 Cabinet Workbench (A48081)
2025 7ft 10 Drawer...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2022 Club Car...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
