New septic and leach line: Infiltrators vs pipe /poly tank vs concrete?
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #11
A pump tank only runs about 1/4 full under normal conditions. The septic inspector won’t allow it here. I doubt you’d have any trouble once it’s buried and settled but they’ll sure float out when they’re left uncovered for inspection.
you must have higher water tables where you live. I saw a concrete swimming pool lift out of the ground when it was emptied to be acid washed back in California... a site to behold.
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #12
High water tables is no problem here. My concern - sufficient cover over basaltic bedrock to allow a drain field. That's why I have a pump tank. Pressure drain field is some 275 feet away from pump tank.
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #13
I hate pump tanks for 1 reason. Sooner or later that pump will fail. Usually at the most inopportune time. The guy i did alot of work for hooking up the pump systems, and believe me when you get into time dose septic systems the electronics start to get complicated, knew that i ONLY worked on new systems. If the unit failed that was in use many years.... dont call me. Aint enough money in the world.
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #14
Poly tank hands down-more durable, easier to handle-big benefit if doing install yourself.
My recently permitted and installed system has 2 poly tanks (1500 and 1000 gallon dual baffle)-easy to handle off of trailer with my backhoe boom.
Have 5 100’ laterals using low profile infiltrators-in my region, gravel and pipe isn’t even allowed anymore since infiltrators are considered more reliable and thought to do a better job of distributing the effluent in the drain field. IMG_1106.JPGIMG_1120.JPGIMG_1127.JPG
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #15
The only down side to a poly tank. If your area experiences seasonal high ground water - it may be necessary to strap side weights - concrete weight blocks - on the side of the tank to keep it from floating. This would only be a problem when the tank had routine pumping for maintenance.
I have no experience using the poly tanks WRT longevity but have heard NOT to use them if you have high groundwater issues. I have no issues with concrete and would use it again especially if its cheaper and easier to install.
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #16
Have 5 100’ laterals using low profile infiltrators-in my region, gravel and pipe isn’t even allowed anymore since infiltrators are considered more reliable and thought to do a better job of distributing the effluent in the drain field.View attachment 666783View attachment 666784View attachment 666785
holy heck, are you running a hotel?
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #17
My thanks to everyone for taking the time to respond. This has been very helpful. I made contact today with a septic system installer and he recommended that I first have the system 'engineered'. I did not do that when I put in a new leach line many, many years ago, but I am totally willing to do that now. I pulled up the County requirements re septic systems. There are many very specific requirements that an engineer of such a system could more easily address so I can (a lot I would likely struggle with) so I can see why having all that 'engineered' makes sense, but it is not required that the system be 'engineered'. I trust the septic installer who made the recommendation so will likely arrange for that. Cost is $2,500 which is a lot but not a lot to get it done right.
Again, my thanks.
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #19
I went with a poly tank, but two laterals done the conventional way of stone / 4" perforated pvc pipe. For our area, it was the most cost effective method.
/ New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #20
There’s no way I’d spend $2500 to have a system “engineered” I’d take that money and overdo it by double if it would make you feel better. Locally the state office provides a sheet of the minimum requirements they deem necessary for the soil conditions and bedrooms.
JOHN DEERE 331G SKID STEER (A62129)
JOHN DEERE 331G...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Abbriata M50 (A60463)
Massey Ferguson 4710 (A60462)
Massey Ferguson...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
72" Grapple Attachment (A60462)
72" Grapple...
