beowulf
- Joined
- Dec 31, 2003
- Messages
- 1,330
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
We are in preliminary planning stages for building a second home on our 90 acres for daughter and SIL. Now getting estimates for construction, grading, well, new electrical, water storage (fire dist requirements) and septic-leach field.
Re the septic and leach field there are a couple of decisions to make:
1) poly vs concrete for tank
2) pipe and gravel vs infiltrators for leach line.
I have researched a bit about the pros and cons for tank types and leach field options, but always like to get advice here - usually the best source.
Pertinent to the issues:
-when I replaced our home's septic a few years ago I went with a 1500 gallon poly tank which was the strongest they had (called a Bruiser tank) and the installer was impressed with it vs concrete. It was a tank that they promote as being one that is strong enough that you can back fill even before you fill the tank with liquid, which I was told you could not do with regular poly tanks.
-I replaced a concrete tank that was very old and had cracked (it was never driven over but was really old and sort of an upright concrete culvert system).
-there will be no chance of upheaval or drive-overs given where the tank will be situated.
-there is access to the site so a concrete tank could be dropped in.
The home site is in an area where there is a slope about 20-30 feet on 3 sides beyond the home site pad - so, I guess adequate drainage overall.
Anyway, I am leaning toward a poly tank and infiltrators, but willing to listen and reevaluate all options.
