New septic and leach line: Infiltrators vs pipe /poly tank vs concrete?
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #11
A pump tank only runs about 1/4 full under normal conditions. The septic inspector won’t allow it here. I doubt you’d have any trouble once it’s buried and settled but they’ll sure float out when they’re left uncovered for inspection.
you must have higher water tables where you live. I saw a concrete swimming pool lift out of the ground when it was emptied to be acid washed back in California... a site to behold.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #12
High water tables is no problem here. My concern - sufficient cover over basaltic bedrock to allow a drain field. That's why I have a pump tank. Pressure drain field is some 275 feet away from pump tank.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #13
I hate pump tanks for 1 reason. Sooner or later that pump will fail. Usually at the most inopportune time. The guy i did alot of work for hooking up the pump systems, and believe me when you get into time dose septic systems the electronics start to get complicated, knew that i ONLY worked on new systems. If the unit failed that was in use many years.... dont call me. Aint enough money in the world.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #14
Poly tank hands down-more durable, easier to handle-big benefit if doing install yourself.
My recently permitted and installed system has 2 poly tanks (1500 and 1000 gallon dual baffle)-easy to handle off of trailer with my backhoe boom.
Have 5 100’ laterals using low profile infiltrators-in my region, gravel and pipe isn’t even allowed anymore since infiltrators are considered more reliable and thought to do a better job of distributing the effluent in the drain field. IMG_1106.JPGIMG_1120.JPGIMG_1127.JPG
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #15
The only down side to a poly tank. If your area experiences seasonal high ground water - it may be necessary to strap side weights - concrete weight blocks - on the side of the tank to keep it from floating. This would only be a problem when the tank had routine pumping for maintenance.
I have no experience using the poly tanks WRT longevity but have heard NOT to use them if you have high groundwater issues. I have no issues with concrete and would use it again especially if its cheaper and easier to install.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #16
Have 5 100’ laterals using low profile infiltrators-in my region, gravel and pipe isn’t even allowed anymore since infiltrators are considered more reliable and thought to do a better job of distributing the effluent in the drain field.View attachment 666783View attachment 666784View attachment 666785
holy heck, are you running a hotel?
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #17
My thanks to everyone for taking the time to respond. This has been very helpful. I made contact today with a septic system installer and he recommended that I first have the system 'engineered'. I did not do that when I put in a new leach line many, many years ago, but I am totally willing to do that now. I pulled up the County requirements re septic systems. There are many very specific requirements that an engineer of such a system could more easily address so I can (a lot I would likely struggle with) so I can see why having all that 'engineered' makes sense, but it is not required that the system be 'engineered'. I trust the septic installer who made the recommendation so will likely arrange for that. Cost is $2,500 which is a lot but not a lot to get it done right.
Again, my thanks.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #19
I went with a poly tank, but two laterals done the conventional way of stone / 4" perforated pvc pipe. For our area, it was the most cost effective method.
   / New septic and leach line: Infiltrators vs pipe /poly tank vs concrete? #20
There’s no way I’d spend $2500 to have a system “engineered” I’d take that money and overdo it by double if it would make you feel better. Locally the state office provides a sheet of the minimum requirements they deem necessary for the soil conditions and bedrooms.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
UNUSED Metal Three-Layer Rolling Tool Storage Cart (A50860)
UNUSED Metal...
2025 13ft X 20ft Single Garage Metal Shed (A48081)
2025 13ft X 20ft...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
