Separating Ford 1520 with HST
   / Separating Ford 1520 with HST #1
diphilanatx
Cleburne, tx
Hinomoto E2004
Looks like I am needing to replace the clutch. Do I need to drain the hydraulic fluid before splitting it. It seems to be a generic note when working on the tractor. My fluid is still clear and I hate to waste it. Any ideas? Thanks
   / Separating Ford 1520 with HST #2
Then drain it into a clean container and reuse it.
Hoping I could eliminate all that mess and having to strain it a couple times. But yea.
   / Separating Ford 1520 with HST #4
If clutch is a dry clutch in bell housing between engine and HST tranny housing you may not have to drain it. You would most likely have to remove a couple of hydraulic lines that may want to drain it though. If these can be removed and ports plugged again you may have a chance.
Cool. That was my thinking also to try. But could also be messy. lol
   / Separating Ford 1520 with HST #6
Working on tractors is always messy. The only way around it is to have someone else do the work. 🤣
   / Separating Ford 1520 with HST #7
If you don't already have the service manual for that tractor, it's worth the investment. I got a digital download of the manual for my tractor, and it has been a big help (especially when we had to split the tractor to replace a cracked clutch housing.)
Well, after many, many hours of studying the Service Manual, studying the Parts Manual, I went back to the basics. Found out the clutch linkage was too tight like riding the clutch. After adjusting that, Praise the Lord, I don’t have to split it. It’s running good. I do feel sort of stupid not going back to common sense mechanics. But it works.
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
Alamo SHD96 Flail Mower
Alamo SHD96 Flail...
