Self Centering Drill Bits
/ Self Centering Drill Bits #1
jigs_n_fixtures
Salmon, Idaho
TYM T293 CAB, & T233
I’m building a tote for my three point hitch, and want to install e-track to secure things with. I need to drill a bunch of holes which line up with the holes in the track to mount them. And, I am having a hard time trying to keep all the holes I’m drilling into the tote lined up with the holes in the track. Does anyone know a source for a self centering/indexing drill bit in 5/16-inch or 8-mm?
/ Self Centering Drill Bits #2
Can you clamp and use the e track as a guide pattern?
/ Self Centering Drill Bits #3
Didn't know that there was a self centering drill bit ... BUT if you lay down "E" track and use a "transfer center punch" through holes in track and use small bit for pilot hole so it does not drift off punch mark then go to desired size hole , you will probably have a better success rate.....
Maybe some thing like in link below may help...
Alos drilling one hole in base at each end of track will stabilize/hold it in place as you center punch or drill all the rest of the holes to mount it....
I’ve tried that, but the holes are 3/8 diameter, and I don’t want to spend the money or time finding flathead 3/8 bolts that are affordable. The only 3/8 flatheads local are the grade ten or twelve, in the little drawers, which cost over $2/each, and no one in town has more than four or five in stock. I even looked on Amazon and eBay, and the industrial supply sites trying to find 3/8 flatheads for a reasonable price in quantities. Seems no one is making flathead bolts that aren’t high strength and expensive. They have forgotten that sometimes you just need a flush fastener, that isn’t holding the world.
Other than a guided/indexed bit, the only solution I can think of is go between the factory counter sunk holes, and drill, then countersink new holes as I mount the tracks. That way the holes in the track match exactly to the holes in the tote frame.
Another justification to buy a good 3D printer so I can make my own custom parts, jigs, and fixtures.
/ Self Centering Drill Bits #5
/ Self Centering Drill Bits #8
Could you just make a collared bushing from Gr8 steel to hold the 5/16 centered?
Tried the indexing punches. But the punch that makes the center punched hole sticks out past the end, so you can’t get it indexed on the counter sunk hole.
But I just had a thought, that I may be able to find a compression fitting, which would index on the counter sunk hole, and act as a guide for the index punch. I’m off to the hardware store.
But, if anyone knows of a source for self centering/indexing drill bits in larger sizes, please post.
Thanks, Jigs.
/ Self Centering Drill Bits #10
/ Self Centering Drill Bits #11
Could you temporarily mount your e-track parallel to, but offset from (say 1") the e-track's permanent position. Then make a jig with a 3/8 stub for the etrack holes and with a 5/16 drilling hole offset 1" from the 3/8 stub?
/ Self Centering Drill Bits #12
Salmon ID!
Been through there heading down to Stanley. Absolutely a beautiful area. 👍
/ Self Centering Drill Bits #13
/ Self Centering Drill Bits #14
Vix Bits, not Vex. Vix Manufacturing company. I think it was patented a long time ago but long since expired so many people make them now.
Your right, thanks for the spelling error alert.
I made the edit before time expired.
OK, the lessons learned post. I got the drill bit centered up on the countersunk holes by using flair nut coupling fittings, and a bit the just barely fit through the inner hole of the fitting. Then used that hole as a pilot for the larger drill bit.
Another reason to buy an assortment of drill bushings and a 3D printer. The ability to make custom jigs which do what I want accurately.
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
Bestway 750 Sprayer (A66285)
Bestway 750...
Metal Sunflower Statue (A64127)
Metal Sunflower...
2006 Deere 160CLC (A64126)
2006 Deere 160CLC...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
