Self Centering Drill Bits
/ Self Centering Drill Bits #1
jigs_n_fixtures
Salmon, Idaho
TYM T293 CAB, & T233
I’m building a tote for my three point hitch, and want to install e-track to secure things with. I need to drill a bunch of holes which line up with the holes in the track to mount them. And, I am having a hard time trying to keep all the holes I’m drilling into the tote lined up with the holes in the track. Does anyone know a source for a self centering/indexing drill bit in 5/16-inch or 8-mm?
/ Self Centering Drill Bits #2
Can you clamp and use the e track as a guide pattern?
/ Self Centering Drill Bits #3
Didn't know that there was a self centering drill bit ... BUT if you lay down "E" track and use a "transfer center punch" through holes in track and use small bit for pilot hole so it does not drift off punch mark then go to desired size hole , you will probably have a better success rate.....
Maybe some thing like in link below may help...
Alos drilling one hole in base at each end of track will stabilize/hold it in place as you center punch or drill all the rest of the holes to mount it....
I’ve tried that, but the holes are 3/8 diameter, and I don’t want to spend the money or time finding flathead 3/8 bolts that are affordable. The only 3/8 flatheads local are the grade ten or twelve, in the little drawers, which cost over $2/each, and no one in town has more than four or five in stock. I even looked on Amazon and eBay, and the industrial supply sites trying to find 3/8 flatheads for a reasonable price in quantities. Seems no one is making flathead bolts that aren’t high strength and expensive. They have forgotten that sometimes you just need a flush fastener, that isn’t holding the world.
Other than a guided/indexed bit, the only solution I can think of is go between the factory counter sunk holes, and drill, then countersink new holes as I mount the tracks. That way the holes in the track match exactly to the holes in the tote frame.
Another justification to buy a good 3D printer so I can make my own custom parts, jigs, and fixtures.
/ Self Centering Drill Bits #5
/ Self Centering Drill Bits #8
Could you just make a collared bushing from Gr8 steel to hold the 5/16 centered?
Tried the indexing punches. But the punch that makes the center punched hole sticks out past the end, so you can’t get it indexed on the counter sunk hole.
But I just had a thought, that I may be able to find a compression fitting, which would index on the counter sunk hole, and act as a guide for the index punch. I’m off to the hardware store.
But, if anyone knows of a source for self centering/indexing drill bits in larger sizes, please post.
Thanks, Jigs.
/ Self Centering Drill Bits #10
/ Self Centering Drill Bits #11
Could you temporarily mount your e-track parallel to, but offset from (say 1") the e-track's permanent position. Then make a jig with a 3/8 stub for the etrack holes and with a 5/16 drilling hole offset 1" from the 3/8 stub?
/ Self Centering Drill Bits #12
Salmon ID!
Been through there heading down to Stanley. Absolutely a beautiful area. 👍
/ Self Centering Drill Bits #13
/ Self Centering Drill Bits #14
Vix Bits, not Vex. Vix Manufacturing company. I think it was patented a long time ago but long since expired so many people make them now.
Your right, thanks for the spelling error alert.
I made the edit before time expired.
OK, the lessons learned post. I got the drill bit centered up on the countersunk holes by using flair nut coupling fittings, and a bit the just barely fit through the inner hole of the fitting. Then used that hole as a pilot for the larger drill bit.
Another reason to buy an assortment of drill bushings and a 3D printer. The ability to make custom jigs which do what I want accurately.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Monosem Planters (A64126)
Monosem Planters...
1995 MACK RD690S T/A DUMP TRUCK (A64277)
1995 MACK RD690S...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
