Segmented vs. Solid mower tires
/ Segmented vs. Solid mower tires #1
DB Pilot
SW, New York
Case Farmall 65A, L3800 Kubota, BX2200 Kubota
Just found some 10" x 3.25" segmented tires for my 6' Phoenix rear mount mower deck. The original roller tires were solid hard rubber. Anyone have any experience with the segmented ones as they look very durable but seem to be a bit cheaper?
I have no idea how I bent the fork mount for the tire but, with the wheel not running straight, I did a perfect job of tearing up the solid tire. I know that the segmented tire on the back of the brush hog can really take a beating so unless the smaller ones can't hold up I will probably give them a try.
Bought the segmented tire will let you know how it works out. Should arrive about 9/2/2013. :eek:ptimist:
Well actually today is the 2nd. So I don't know when it will arrive but, thanks to Gary I am even more optimistic.
/ Segmented vs. Solid mower tires #3
Every bushhog I have seen has segmented tires. They work and last forever
/ Segmented vs. Solid mower tires #4
Our Woods DS1260 pull type has foam filled airplane tires, but everything else uses segmented wheels, both are very durable, segmented much cheaper.
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
2001 FORD F-250 SUPER DUTY (A67714)
2001 FORD F-250...
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65054)
(INOP) 2006...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
1999 INTERNATIONAL 4700 4X2 FLATBED DOVETAIL TRUCK (A65057)
1999 INTERNATIONAL...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
