Seeking advice on a 1-time Welder purchase
   / Seeking advice on a 1-time Welder purchase #11
the power source looks exactly the same as mine.
Oh yeah, I've seen them before, not sure I've run one before or not, but who can remember too many machines, too many years. :laughing:
   / Seeking advice on a 1-time Welder purchase #12
I have had a 220v Hobart Handler 175 MIG for 12 years. I have run a lot of wire thru it, and love it. I belive the current version is the 187. Have fabbed a few trailers and truck beds and my current woodsplitter project. Full setup right now is probably in the neighborhood of $800.00. I would replace it with the same machine.
   / Seeking advice on a 1-time Welder purchase #13
I'm not an expert but generally the combo units cut corners and if one process goes down it might put them all out of action.
A plasma cutter may also be an option even though you are experienced with O/A. They are quite the luxury.
Just to help out in the expert's responses - what is your budget? Will you use the welder occasionally or is it a more regular thing? Are there specific projects to be done and then just maintenance from then on?
Trying to learn the new process(es) by yourself will be quite a challenge. Maybe enroll in a local community college class to see what you like to do and how to do it. The boiler weldor might be able to give you some tips on his next trip out - and he has the equipment to demonstrate.
I wouldn't be affraid of the Multi process units out there. They have them figured out. Not much corner cutting on Miller XMT's Thermal Arc MST's or Lincoln Invertec's. Between the 3 of them I would guess 5 - 6 million sold and most still in service. Old inverters were a problem but new technology and great warranties have changed all that. It doesn't matter what you buy, You will love it.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Shop Smith (A57454)
Shop Smith (A57454)
(22) Assorted Webbing Slings (A57453)
(22) Assorted...
John Deere 2555 Tractor with Loader (A57453)
John Deere 2555...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
