See under the FEL bucket lights on BX23
   / See under the FEL bucket lights on BX23
The lights are Hella fog lights - I bought them from www.tirerack.com - it was the cheapest place I could find for the set. The lights themselves were not cheap, but they were small and round and would fit into the tubing that I had. I was trying to avoid installing a light that was too big in that spot.
I had actually fooled around with a number of different lights including some regular work lights, some fog lights from a Ford Super Duty pickup, etc. and as I test fitted each of them I realized they were too big for the spot I wanted to put them in. The setup I went with works great - it does not contact the front tires at full lock and with the tractor on a slope (axle tilted) and they do not interfere with taking off the engine cover - which means the lights can stay attached and do not have to be removed when you have to get the cover off.
Here are the lights I used:
http://www.tirerack.com/accessories/hella/micro_de.jsp
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
BAT WING SHREDDER (A58214)
BAT WING SHREDDER...
