crashz
Elite Member
I move it to small jobs just about every weekend. The federal guideline is pretty clear and i won't repeat, but it is educational and I do recommend reading it.
I have evolved my tie down routine based on what has worked and what could have been a problem. I started with using the large 2" 5,000lb ratchet straps and two smaller straps for the mower and loader bucket, but found two of the large straps beginning to fray after a couple of moves. Had me worried that a long haul might allow it to fray through without me knowing. So I replaced the larger straps with chains and lever binders. That gave me a better piece of mind, but always had trouble binding down the load either too tight or too loose. and almost always resulted in loose chains after a few miles down the road. Switching to the screw type binders solved that issue.
Now I have approximately 16,000lbs of restraining capability for a 5000lb load. Only downside is that it takes a bit longer to tie everything down. But its safe and I've never had a chain loosen or a fray issue since.
