Security & Theft Securing tractor from theft
/ Securing tractor from theft #91
This has been an interesting thread. I started not to read it, thought it might be boring. If the equipment is in a shed you can hang treble fishhooks from the ceiling with monofilament line every foot or so around it and put a game camera in, one with a flash. I know a guy who had a peeping tom looking in his daughter's window from time to time. The flash made the guy take off, the hooks hanging from the eaves and in the bushes stopped him, the other pics of him taking the hooks out were what got the guy convicted.
I know that putting up the hooks would be a hassle in reality, but a removable strip of wood with them attached, maybe okay. But even if you caught the guy you might get sued, especially if you hook an eye.
I vote for insurance, although I like the wired-in pepper spray idea. I think that a couple of cannisters with a sensor and actuators would work and could be a money making idea.
/ Securing tractor from theft #92
RobJ said:
HAng it from a tree, that'll keep them son of a bears away! :D
Actually splash on some black, red, brown, etc paint. Knock some dents in it. Pour a large amount of oil under it. Add some stick on bullet holes in the engine block. Let the air out of a couple tires, put R-1's on it(ya know R-4 are what people want), and white walls on the front. Then park it on the street. It'll be there next week.
I'm thinking I have it good by owning a nearly 30 year old tractor with previous, various oil leaks underneath it, badly faded paint and a bent muffler. The Japenese labels are probably helpful too since no one can read them! The uneven concrete in the corncrib might be helpful too since I keep the loader (with teeth) down in the full dump position. Trying to drag it out without lifting the loader would probably result in it tipping over once it hit a large piece of concrete sticking up behind it. Of course I wouldn't be too happy to come home and find my tractor laying on it's side.
If I ever buy a new one I'll insure it.
/ Securing tractor from theft #93
IMHO.. thieves have one place they need to be... 6feet under... Our laws int heis country need to be continued to change to support that as well..
soundguy
/ Securing tractor from theft #94
Egon said:
How many wires in the bundle?:D
Egon, It only takes one wire in the bundle to make it work. If the machine is moved the wire gets pulled out of the socket or broken and that sets off the alarm. The other wires in the bundle are to make it harder on the guy who is more electronically inclined.
The current loop can be passed through several of the conductors in the bundle and several of the other wires are not continuous as they have been cut (can't see it as the work is hidden under shrink tubing. These are used as N.O. sensors whereas the continuous wires are used as a N. C. sensor. Jumping a N.O. lead sets off the alarm. Cutting a N.C. lead sets off the alarm. The more wires the higher the odds are against the bad guy getting lucky.
Even a 6 pair phone cable makes it unlikely you will guess the right thing to do to defeat the cable through the equipment security system but if you want to increase the number of permutations and combinations you have only to use a data cable or similar with many many conductors. Note that each conductor needs only be 24 ga or so, really small multi-strand so the many wire cable is not too big, inflexible, and too much hassle.
Recall that if you pull all 6 spark plug wires off of a 6 cyl car there are 720 uniquely different ways to put them back and only one is right. If it is an 8 cylinder engine then there are 40,320 unique ways to replace the wires and again only one is right. Similarly increasing the number of wires in the cable makes it less likely the bad guy will get lucky. The problem for the bad guy is to know which wire(s) can be cut and which wires can be jumped without setting off the alarm. Cutting a wrong wire or jumping a wrong were will set off the alarm. Unplugging the cable from the wall will set off the alarm.
In general it is reasonable to suppose that anyone sufficiently sophisticated and appropriately instrumented to be able to defeat this system would not be a likely candidate for stealing your tractor.
Pat
/ Securing tractor from theft #95
Just checking up on how complicated it could get.
Sounds like disconnecting a main breaker On the feeder line to area would be a simpler solution.:D :D Course there is always the chance of a backup generator kicking in.
Then again maybe just taking the cable would be okay with the price of copper now!:D :D
Or let see, just wait till no ones home???:D :D :D
/ Securing tractor from theft #96
A piece of cable is not very complicated to put into service but can be pretty complicated to defeat when used as described. Monitored alarm system gets the gendarmes called whether or not I am home. The most gun happy cop in the area is on my "to be called" list.
I have no clue what you are talking about breakers and backup generators.
have a battery backed up monitored alarm system with cell phone backup as well. If both phone connections (wired and cell) go down that is an alarm condition so cutting the phone line and jamming the cell phone. Just sets off the alarm. Besides, cell reception is what you can jam and cell transmission is what gets the cops called. To jam the transmission you would have to go to the nearest several cell sites (cell technology will find the best available cell site.) Jam one and it looks for another. My system doesn't use the nearest site for its primary access, just as a backup.
Again the system can be defeated but... It is highly unlikely that a super technically savvy and well equipped thief will be wandering around rural Oklahoma looking to steal an implement or a tractor.
The alarm system works with or without electric utility power.
Stealing the cable for a buck or two copper value will risk your being shot so is pretty stupid. You could just pick up a few discarded soda cans to get metal to recycle and not run the risk of dieing for $1-2.
Around here people just hanging out get noticed and often questioned. I braced a guy parked on my highway frontage and he was a process server looking to lay paper on a deadbeat dad who would drive by on the highway and turn on a section line to go a few miles north of me. I gave him permission to pull onto my property and "hide" his vehicle by an outbuilding. If he would have had trouble producing ID and a coherent story I would have let him try his story on the local law.
Pat
/ Securing tractor from theft #97
Thank you for the updated information Pat. I knew it was a more complicated system than appearances would lead one to beleive.:D :D :D
Now one can come up with a simple solution to bypass the system with really no knowledge of the system!:D :D
Wow!....didn't think I had started a 10 page thread.
I decided...all risk insurance, and I keep it out of sight best I can.
If they try when I'm there, they are dead.
/ Securing tractor from theft #99
You will have to explain that to me (on the side please) as I don't see how you draw that conclusion.
Now as to jcummins... There are several but distinct hot buttons on this site of which the mentioin of any single one or combination thereof is guaranteed to either elicit many pages of discussion or precipitate a brouhaha of great proportion so as to approach the magic conveyor in popularity.
Mostly, any given theft target can be stolen but the combination of time, effort, expense, expertise, and such that must be brought to bear may exceed the motivation and ability of the thief. In general, making your equipment significantly harder to steal without being detected than the equipment of the folks around you is all that is required to significantly reduce your odds of loss.
A lot of what passes for loss prevention strategies is just whistling in the dark. If no one ever tries to steal your tractor, then whatever you may have done as a loss prevention strategy will impress you as successful. You may have been sprinkling black pepper on your tractor tires after parking for the last 10 years and since your tractor was never stolen, it worked, huh? Ranks right up there with the tag line, " I plan to live forever and so far so good!"
Most of the cute little tricks people suggest for loss prevention will go unnoticed until after the winch trailer equipped thief tries to fire it up to unload it. Yeah, it will inconvenience him THEN but so what, your tractor is still gone.
Pat
2017 Ford F-350 XL (A60462)
2017 Ford F-350 XL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
