Security & Theft Securing tractor from theft
/ Securing tractor from theft #81
Tasers are pretty cheap ($350) compared to tractors. Wire up a couple tasers aimed at where a person would be while stealing the tractor (including the tractor seat) Since the would be thief is unaware of the Tasers he will not be looking for the secret switch to disarm them and will be in for a shocking experience.
Do you suppose after being tased the thief will have the presence of mind and hudspuh to continue with his original intent? Not bloody likely.
Alternatively squibbs could be fired to deploy dye packs like used in banks to mark a robber.
Both are non-lethal, usually, but I suppose some delicate thief may have a heart attack when blasted with dye.
A net composed of multi-strand stainless steel cable in small diameter (like used on U-control model planes or as piano wire) could be deployed over the tractor and the fence charger to which it is connected switched on when the tractor is disturbed. This could be quite exciting for the would be thief and if used in conjunction with dye packs might even help ID the bad guy.
Pat
/ Securing tractor from theft #82
Umm I seem to remember that it had to be easy for the owner to implement. I believe the phone alarm with the cell phone backup is a good idea, but instead of just calling when the tractor is disturbed, have it send a text message once an hour. Even if they jam it or cut the lines or what ever, if you don't get a text message, you know something is wrong. I work in Information Services and we do something similar to make sure our servers are up and running. We call it a heart beat, no heart beat and something is wrong. And I also agree with adding other deterrents, such as removing the battery chaining it to other equipment or large unmovable objects. Yes thieves can work around that stuff, but it slows them down. Also put up signs warning that you have a security system and cameras. Even if you don't have them, thieves want easy, they are lazy, they want the easy score. Why take a chance with your tractor when they can go down the road and steal your neighbors unsecured tractor. You can what if this to death, but what it really boils down to is risk vs reward. And if you do some simple things thats easy for you to implement, but makes it hard on a thief, more then likely the thief will skip you and look for an easier target.
/ Securing tractor from theft #83
On my tractor there is a 'neutral start' safety switch located at the 'hi-neutral-low' shifter lever to prevent accidental starting in gear.
Some tractors have seat switches that require the operators weight in order to engage the the starter.
Simply pulling out one of the wires from the safety switch creates an open circuit thereby preventing starter engagement.
It is simple enough to pull 'just enough' to break the connection but not totally out so as to be evident.
I always store it with that open circuit.
Matter of fact the key being broken in the switch makes the switch always live and my key is now a stubby screwdriver! (but naturally nobody knows that the key in is there).
Been that way for over 8 years.
/ Securing tractor from theft #84
mentat30, The heavy equipment loss prevention system I designed (20 + years ago) used your "heartbeat" approach. It sent frequent "I'm OK" messages via mountain top repeaters and if it quit sending them you had a potential theft in progress. This predated cell coverage but the basic idea is the same.
A system that sends a trouble alert can be defeated before it sends the trouble alert but a system that sends a "heartbeat" is much much harder to defeat (nearly impossible, especially at the level of technology to be brought to bear by a tractor thief.)
Pat
/ Securing tractor from theft #85
It's already been goon over about a dozen times.. but thief showing up to grab a tractor is likely equipped with jumper wires, as he knows he will be jumpering start switches.. etc. Don't take much to energize fuel solenoids and jump around key switches, and jump starter solenoids, past any lockouts in the system. A hundred lockouts in the start system can be bypassed by a paperclip jumping from bat hot side of the solenoid to the coil side..
soundguy
/ Securing tractor from theft #86
soundguy
Soundguy, You keep telling the unvarnished truth and your popularity rating will take a dip! You go around popping bubbles and dashing cold water in the faces of the sleep walkers and you will not get a gold star by your name.
In addition to the ease with which you can jump a tractor, irrespective of "secret" switches, opened up connections etc, it is not a requirement to run the engine to steal it.
Some thieves do not attempt to start a tractor. They just hook up to it and winch it onto the trailer and drive away.
Of course some thieves do want to start it and making it hard to start is better than nothing. Making it hard to load unnoticed is also a good deterrent. If it is hard to start and hard to load and takes too much time and attracts too much attention it is quite likely a thief will look for easier pickings. Anything you can do to slow the bad guy down and attract attention is good for you and bad for the bad guy.
One guy added a valve to his injector system that when opened allowed air into the system. Diesels hate air in the system and will refuse to run, even if you were lucky and managed to start it. I would think a hidden valve to cut off the fuel would be a better deal but I wasn't consulted.
I have been throwing saw dust over my left shoulder while whistling Dixie after parking my tractor and my tractor has not been taken. No attempt has been made to take it. Apparently this is an effective elephant repellent too as I have not seen an elephant on my property during this period as well.
Just because you are doing "something" and your equipment hasn't been stolen (YET) does not indicate that the action you are taking is guaranteed to be the reason it hasn't been taken. Were any attempts made?
Most of us are lazy and will not do much, even to secure a high dollar investment if it requires much hassle. I can include my tractor or any equipment near my barn or my shop under the umbrella of the monitored alarm system. A loop of multi-conductor wire run through the tractor and back to the shop or barn includes the item in the monitored security system.
To take the equipment you have to break the wire or unplug it from the wall. Either sets off the alarm. The clever crook might consider jumping the system but... jumping the wrong wires in the bundle sets off the alarm. Cutting the wrong wires in the bundle sets off the alarm. There is a small but finite chance that a savvy electronics trained person might be able to defeat the system. I'd give a good electronics technician or an engineer familiar with alarm systems about one chance in a few thousand. So my idea is not perfect, but I think it is good enough.
If anyone is interested in the details, just ask and I will explain it. It is pretty simple to set up. If you don't have an alarm system to use it with then you can buy one or build one cheaply. I posted a schematic and picture of the finished product for a really simple one.
Pat
/ Securing tractor from theft #88
Come to think of it. I havent seen any elephants on my property either.
/ Securing tractor from theft #89
I know I know! :rolleyes:
It's just that so many people think they can theft proof a machine by just hiding the keys.. lots of gullable people out there.. so I tend to beat the subject to death..
soundguy
Pat
/ Securing tractor from theft #90
HAng it from a tree, that'll keep them son of a bears away! :D
Actually splash on some black, red, brown, etc paint. Knock some dents in it. Pour a large amount of oil under it. Add some stick on bullet holes in the engine block. Let the air out of a couple tires, put R-1's on it(ya know R-4 are what people want), and white walls on the front. Then park it on the street. It'll be there next week.
2018 Kubota SVL95-2S (A60462)
2018 Kubota...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
Kubota L3130 (A53317)
SDLanch SDLE20 (A60463)
SDLanch SDLE20...
4021 (A59228)
4021 (A59228)
