Security & Theft Securing tractor from theft
/ Securing tractor from theft #71
My dad and granddad both left their tractors in sheds completely unsecured since 1970, and they have never been bothered. Gemini mentioned the reason why: you only have an occasional car pass by. Neighbors notice things that are out of the ordinary.
I went to a downtown school (Georgia Tech) where car theft was a constant threat. The solution was easy for the typical car. All you did was add any small measure of deterrent. Most of the thieves were not professionals, so they would simply move on to the next car. I drove one of the most-stolen cars at the time: Chevy C1500. I parked under lights, used the Club, and moved my truck often. I never had a problem.
One point from earlier that I disagree with... a rollback can't handle a container full of a tractor, implements, and misc tools/etc. Especially if you have done anything like bolting it down to a foundation or building a vehicle fence in front. Double-especially if it is a 40' container.
I read through this entire thread, but nobody mentioned an actual problem with theft. So, have you guys had problems with theft? Anybody hit with a super pro with rollbacks, plasma cutters, diamond grinders, etc?
/ Securing tractor from theft #72
My problem wasn't so much with theft but vandalism. Kids nowadays have no respect. I remember one morning going out to find one of my 4 wheelers with the ignition cylinder cut out. Though I did get a chuckle when I found 1 of my rear tractor tires 'slashed'. These are 4' tires with tubes filled with anti-freeze for added weight. The tires were shot and getting replaced anyway. But apparently these chuckleheads must've hacked at the side of the tire with an axe (below the rim). I hope they got a good shower when all that nasty 15 year old anti-freeze and water came gushing out.
I have resigned myself to the fact that if someone wants your stuff bad enough they will get it. I just make sure the effort to get my stuff is not worth the reward.
I used to have a sweet '71 chevelle with a built 350 sbc, my wife was afraid of someone stealing it after I showed her how easy it was to slim jim it and pop the ignition (long story involving a boat and a set of keys without a float). Anyway what I wound up doing was installing a toggle switch for my headlight high beams. Then I wired the relay from my electric fuel pump to the foot high beam button. If someone tried to steal my car it would start and run fine for maybe 100' then shut off and not start until the fuel pump was turned on. Never had to test it though.
/ Securing tractor from theft #73
there are a fiew things i can think of. the contest was for in the middle of a field.
a small howler aprox hockey puck sized strong container that would be dropped uner the bucket before final lowering 180 db + will solve most thieves. add a trimble device inside the cab with a cell (if available) and another howler. any trucking would trip the howler not much else would be movin it. you could put the devices behind pannels of the tractor so you have to know where it is to turn it off. you could make the on off switch easy enough to get to but usless once tripped. somthing that loud would attract attension quickly any idiout near by would be deff. there are some gi frequencys that you could also use instead. teargas dye foam sprayed in all 4 directions would also be a good value added deterant. the puck could be disabled by a pin inserted in to the lock if you knew it was there and the other would not be likely to be noticed. ie if you smoke attach the switch to the ash tray. when it is poped out it is off.
you can add a raideo locator like are used on wild animals those would not be blocked by cell jammers and easy enough to track down. you can also have a detector on your property but not near by and once the trembler is activated the cell unit picks up on it and dials whom you choose. if you keep the howlers out the theef might not know they were noticed till the cops pull them over. the batterys in the animal collers can last up to a year depending on model.
/ Securing tractor from theft #74
In a one of my gun magazines, some company is selling a burglary deterrent for gun shops. When tripped, it floods the room with pepper spray, then resets it self after a certain amount of time. Can you imagine sitting on the seat of the "soon to be stolen" tractor, turning the key that some one thoughtlessly left in the ignition, and instead of hearing the motor come to life, you are doused with the gel type pepper spray (that also has the bright red dye in it).
I know that this is designed for a room, but with a little imagination....
/ Securing tractor from theft #75
Droy we might be talking about the same or competing stuff.... I saw the jell/foam stuff in the edge catalog many years back... it sprayed like a liquid and then foamed up on contact had a lovely witch green dye that would permantly mark the target (3+days before enough skin could be rubbed off...) may have been pepper spray included or tear gass cant remember... know i could get some tear gass paint balls from the same area of the catalog though :D
/ Securing tractor from theft #76
Can you imagine the hassle of ruining all the hunting vests, hats, cammies and on and on when the pepper spray floods the gunstore.
If a pro wants your stuff he will get your stuff. Luckily most pros are not into stealing little tractors. The caliber of thief that is into tractors can be deterred such that he will go elsewhere.
It is the same with the majority of residential burglaries. You don't have to have an impenetrable and impregnable fortress, you just have to harden your residence against burglary significantly better than the majority of your neighbors.
There are plenty of people just parking their tractor where it can be easily loaded up to keep the thieves supplied such that they don't need to be Mission Impossible super experts. You just need to make it hard enough so they would rather take someone else's tractor.
My theft experience in 7 years has been one utility trailer (less than a month old.) It was parked where it could not be seen from the highway. The thieves took it at night cutting the plug off of it to wire the lights so they would not get stopped at night for no lights. It cost me $50 to replace it and I knew better how I wanted it built than the first one so I came out smelling like a rose, it was worth $50 to get a "do over." Of course on the other hand I would have shot the SOB's had I noticed them at work taking it. I park the replacement next to my house over 1/4 mile from the highway.
The only other theft of which I am aware is a stainless steel utility sink which was sitting 100 yds from the highway for well over a year waiting for me too install it in my shop. I bought it used for $40 but it was worth about $1500 or more in the stainless. That theft really ticked me off. I would have loved to "discuss" matters with the individual(s) responsible. Such discussion could very well result in my being attacked by the would be thief forcing me to resort to deadly force to protect myself.
Pat
/ Securing tractor from theft #77
I store tractors and equipment in an old barn about 1.5 mi from my house. The insurance policy gives me piece of mind.
/ Securing tractor from theft #78
Back to the original question, for being out in the middle of the field
I think you have options
You can get a Trailer, or plant some trees to hide it from view and disable as previously stated by others, or build a containment area
STEP 1: 10 tall chain link fence with barbwire outward facing top attachment. Cost should be minimal, as you would only need to build it big enough to surround the tractor. Make sure to also weld some steel between the bars so the fence is not scrap if the links are cut out. This does not need to be so much that someone can稚 get though, just so that the tractor won稚 fit though it. Make sure you get a lock that will make them spend some time on it.
STEP 2: Location Location Location! Build the containment area at the furthest part from the Road or at least far enough that they could not drive or extend a cable out to it if possible. Depending on what your doing with the property, if your field is dug up enough it might not be possible for a flatbed to easily drive out to it.
STEP 3: Disable it to the best of your ability and go as far as heavy chain locking it to two or more sections of the fence. I would have a cart or wheelbarrow that you use to hull the battery and other parts you remove back to your truck. You could easily leave the cart or whatever in the containment area when you are working with the tractor.
In the end, its just going to depend on how far you want to go with it.
Good Luck.
/ Securing tractor from theft #79
patrick_g said:
I pay $5/month for the cell phone backup on my alarm system. If an alarm was installed on the tractor (with cell module) It can call the cops or you or both in case the tractor is tilted ( a virtual mandatory requirement to load it) Of course you need cell coverage in your area. A call to the cops or you is much better than a video of ski masked thieves driving away with your tractor.
An experienced thief knows how long they have before police response. Couple weeks ago my neighbor stops by as I'm out mowing and asks if I've seen anything unusual in the area as there are some homes in foreclosure and one of them had the door wide open and no one there. We were talking about recent home burglaries in our area that no one ever used to lock doors even when away on vacation. A nice looking new SUV drove up the road and I mentioned look at that, it's a vehicle I've never seen before but the boarding stables up the road have vehicles that come and go so you never know. Not long after the vehicle leaves and my neighbor waves to him in a friendly gesture. He then mentions the person was a minority, not to sound racist but it just isn't normal where I live and stands out. The windows were dark tinted and we didn't notice this before. Minutes later a sheriff pulls up and asks if we have seen this vehicle and informs us he is breaking into houses. The crook broke in right under our noses as we were sitting there talking about thefts and the home had an alarm that did send a signal to the cell phone of the home owner who happens to be related to the sheriff who also lives on the road and she had his direct cell number to call, and he was still too late to catch him. He managed to rip a gun safe with guns and cash right out through a window and make off with it and drive back down out our dead end private road in no hurry and wave hello as he did so. They sent every available unit and a helicopter crawling the area but no luck finding him. I know one thing, everyone in this area is well armed and if anyone is ever caught in the act around here there won't be a need for the sheriff, a trial, or a burial plot, one will be chosen for them.
/ Securing tractor from theft #80
That gives me an idea for a new tv show "To bury a theif", I'll volunteer some digging since it's going to a worthy cause hehe.
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
CFG H15R (A60463)
CFG H15R (A60463)
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
FULL SIZED PORTA POTTY (A60736)
FULL SIZED PORTA...
