Securing loading ramps under trailer
/ Securing loading ramps under trailer #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
My GN trailer has ramps that slide into a slot under the trailer.
At the front of the slot they have spring loaded catches (I need to get a picture) that secure the ramp, into the slot.
About a month ago, for whatever reason, one did not get secured and got lost on the road :(
SWMBO swears it was checked, and I am wondering, as it was never a truly positive engagement, if maybe it worked itself loose or worked itself around the catch. The other side ramp was not the factory ramp when I bought the trailer, so I suspect it got lost by the previous owner. The ramp there has several cobbled pieces to make it work.
So, what I am asking / looking for, if you have a really good ramp retention system and you are happy with the latch mechanism that locks your ramps into their stow position, would you be so kind as to shoot a picture? This would be ramps that slide up under the trailer into pockets.
Thanks so much.
/ Securing loading ramps under trailer #2
Mine has a rectangular door with a hinge on the inboard side. The outboard end has a slot which goes over an eye when closed. Any kind of tractor pin goes through the eye to secure the door closed.
Here is the only pic I have available. notice the pins are on chains so I don't loose them!
/ Securing loading ramps under trailer #3
Mine is pretty simple, tube sections welded above and below the ramp slot and a pin that drops down through both, right about in the center of the width of the slot. Even with this, I did have one occurance of the pin bouncing out of the lower tube so now I stretch a bungee between the two (one for each ramp). I can take pics if you are interested but it's nothing fancy at all.
2018 Ford Focus (A61574)
2018 Ford Focus...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
12 Ton Hydraulic Jack (A64127)
12 Ton Hydraulic...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
