Secondary Hydraulics question
/ Secondary Hydraulics question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Does anyone know the hydraulic properties on an 1850 of the Grapple, Thumb, Locking mechanism hydraulics? GPM and PSI? Maybe how it all sort of works compared to the PTO?
Thanks
/ Secondary Hydraulics question #2
Thanks
I have read this thread 3 times and I still cannot understand what your question is!!. The main PTO. and Aux. hookups( non-PTO ) are totally different beasts (flow & pressure are different on both circuits ). Could you make your question a little clearer?:confused:
/ Secondary Hydraulics question #3
I agree, try asking your question a different way, what you have typed makes no sense:confused:
/ Secondary Hydraulics question #4
I think he's looking for the specs on the Aux PTO and the main PTO, to compare them. I can find the info on the main PTO, but not the Aux PTO.
The main PTO is 18 GPM @ 3,200 PSI
What are the specs on the Aux PTO?
/ Secondary Hydraulics question #7
There are three hydraulic pumps on our PT425.
1. Main PTO is rated at 8GPM @ 2500PSI.
2. The auxillary PTO which runs the steering, lift and quick attach circuits is rated less GPM but still 2500PSI. I can't recall exactly, but I think it is 6GPM.
3. The variable volume pump that drives the main drive wheels I have never gotten specs for.
My suggestion would be for you to call Power Trac at 1-800-THE-YARD and just plain tell them you are interested in their product and would like some information regarding the GPM of the pumps so you can decide if it will push the implements that you want to use.;)
Interested? Heck, I bought one. But the truck caught on fire and now it won't show up until Wednesday or Thursday.
Living Vicariously through all of you. My little PT fix. Taking a week off from LA, going to fly up and play around with it and look at all the tulips and apple trees in bloom, then back to reality...
Thanks for the info on the PT. Will call Tazwell on Monday...
/ Secondary Hydraulics question #11
I was a little confused by POWER TRACS definition of a aux. hydraulic circuit (AUX. PTO ) and a main PTO circuit. A PTO supplies power to a gear box on a tiller, bush hog, stump grinder, wood chipper, auger etc. via. a splined drive shaft,as with a conventional tractor. The power trac PTO supplies hydraulic power (flow) to a hydraulic motor powering a brush mower, finish mower, stump grinder, tiller, power auger etc. The aux. hydraulic circuit (or power tracs definition--aux. PTO ) supplies power (flow) to a double acting cyl. powering a hydraulic top link, backhoe bucket curl function, snow/dozer blade power angle, bucket grapple, 4 in 1 bucket, log splitter, quick attachment plate locking pins etc. via. a spool valve. I don't mean to ruffle any feathers but a PTO is one thing and a aux. hydraulic circuit is another thing. They usually operate at different flow rates and psi.:)
/ Secondary Hydraulics question #13
MossRoad said:
We gave up responding to posts on Friday for Lent.
Well I wish I had got the memo, I could have had a steak Friday night instead of fish sticks!:D
/ Secondary Hydraulics question #14
kennyd said:
Then why didn't anyboby respond to the question?
Because, I knew the question, I just didn't know the answer.
/ Secondary Hydraulics question #15
Mmmmm... Mrs. Paul's... what a woman! :)
