Second rear remote crossover
/ Second rear remote crossover #22
The ones we sell are Faster (USA) or Stucchi (Italy). Also the poppet style are less prone to dribbling/leaking compared to the ball style.
/ Second rear remote crossover #23
Come to think of it, they were Pioneer from TSC. It was more expensive, but it did not leak.
Pioneer is made by Parker. So same same as they say.:)
/ Second rear remote crossover #24
The fittings came from discount hyd hose. Maybe I will check tractor supply and see what fittings they have. Probably chinese junk also. Once i get the guage i will do a hydraulic check to see if pressure is building st the coupler. The backhoe goes directly to the sump on the return to keep the fluid cooler.
To check for leakage, remove the work port hoses with valves in neutral, and there should be no flow.
If fluid comes out the work ports, the valve might not be centering correctly or the spools are worn.
/ Second rear remote crossover #25
Being a subframe I can't see why kioti is using your rear remote to run it. That way you have to have the remote in detent. I just think it needs to be plumbed another way on a tractor that size. If it didn't have the rear remote I wonder how it would be plumbed?
