Seat upgrade
/ Seat upgrade #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Challenger tractor seat is really basic and my back is feeling it.
Can anyone suggest a seat upgrade with a nice suspension, armrests & highback/headrest?
Need to keep it on the smaller more compact size so it'll fit.
/ Seat upgrade #2
/ Seat upgrade #4
When I bought my 3215 Mahindra, the first thing that I asked the dealer to do was to change out the stock spring seat and to install a 7520 suspension seat. It is great to have the same seat on both my bigger and smaller tractors.
My point being that the std suspension seat off of the big tractor fits great on my smaller tractor. I doubt that you will have much trouble with any seat as long as it is intended to be used on a tractor.
Good luck with your search, your body will say thanks once you have it installed.
/ Seat upgrade #5
I went from the "basic lawnmower style" seat on my JD to one similar to the one from Northern Tool Northern Industrial Polyurethane Cushioned Tractor Seat | Seats | Northern Tool + Equipment
Has held up really well for 1 yr so far. I had to fab up a new mounting bracket but wasn't too hard. The up and down motion really has helped my back!!!! Ebay has a ton of them for sale;)
jjmarotz: What size Deere is that? Did that suspension seat sit you up much higher than the stock seat did? I've been thinking of getting one of those for my 2320, but wondered about the potential height difference.
/ Seat upgrade #7
My Deere is a 3203, the seat sits you up maybe 1" higher if that. Was the best mod I have done to date!!!!!
Builder... that seat is sweeeeet, hope you have the room to mount that in, sure would be a nice setup.
/ Seat upgrade #9
Builder as you probably remember I take care of a law mowing businesses equipment. They run 37 HP Kawasaki Ferris 3100 series mowers. Anyway these ZTR's have a great suspension and suspension seat that is adjustable to the operators body weight. They are simply amazing, can mow 7 acres a hour so they have to be to run those speeds. Take a look at the Ferris site and look at the 3100 and see if it will work. I am thinking the same thing as you for my Jinma 28 Hp tractor but have not gotten around to it.
Here is a link and a photo. Check it out, I think it will fit the bill.
IS® 3100Z Series, Ferris® Industries, Zero-Turn, Riding Mowers, Ferris Mowers, Mowers, Mower, Commercial Mowers, Lawn Mowers, Lawnmowers, Suspension, Independent Suspension, Munsville New York, Syracuse, New York, Central New York, Mohawk Valley,
Chris
/ Seat upgrade #11
Nice upgrades! Is it 'legal' to put anything but a yellow seat on a John Deere? :D
7102 (A61567)
7102 (A61567)
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
Screen USA CF35D2 Tri Axle Towable Trommel Screener (A61572)
Screen USA CF35D2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
