scut ride comfort while mowing, R4 vs turf vs R14
   / scut ride comfort while mowing, R4 vs turf vs R14 #21
z, especially with the airless tires, great for wheelies though :)
honestly I like them all.
just I can mow my lawn, 5 minutes later till garden, 5 minutes later start rotating 25yd compost pile with one machine.
where most of my "lawn" hay and clover the pto driven mower uses less fuel than any of the 30+hp z units I have used. course blades being 1/4" thick and weighing a ton helps a little there LOL
no right answer, got to use what works best overall for your specific situation.
neighbor has turfs on his, played with it a bit and was small difference between them and r4 I had at the time on mine on open field.
but as stated my lawn is old pasture, tires cant really offset ruts that well. and turfs spun a lot and put me in dangerous positions.
Ok, well that answers it a bit then. How low do you go with the tire pressure?
Also, I notice you mentioned having a stand-on mower, I heard those are better on slopes than z-turns. Not that I'm in the market for another expensive machine, but those things look pretty cool.
   / scut ride comfort while mowing, R4 vs turf vs R14 #23
I cannot attest to the R4 or R14 but my GC2410 with turf tires has a better ride than my Husqvarna 24hp yard tractor. I dont use my GC for mowing because it will compact the ground over time and kill the grass.
To soften the ride on my yard tractor I did reduce the tire pressure.
   / scut ride comfort while mowing, R4 vs turf vs R14 #24
I never bothered experimenting with tire pressure due to my terrain.
friend I work part time for just (3 months ago) got rid of a scag 61" 37hp kawisaki.
I honestly did not like it, was good for field work when bush hog is overkill. I didn't have a lot of time on it however due to my shoulders I was able to handle it. course needing 2 knees replaced meant standing was the issue then LOL
Ok guys, I mowed today with my craftsman garden tractor, paid more attention to why it's a more pleasant experience than with the massey. Simple answer, w/o thinking I hover over the seat some on bumpy areas, with my legs acting as shock absorbers. The seat is lower on the garden tractor, which allows for that.
   / scut ride comfort while mowing, R4 vs turf vs R14 #26
JMHO - if you are looking for "ride comfort" on a tractor - you are looking at the wrong type vehicle.
My Kubota M6040 weighs - 10,100 pounds. On rough terrain it rides rough - rides smooth on the smooth stuff. It has no suspension - no air ride seat - R-1 6 ply tires all around. It's a tractor.
Oh, there's always room for improvement, Oosik. Where there's a will, there's a way.
   / scut ride comfort while mowing, R4 vs turf vs R14 #28
I used to mow with a Kubota 4WD 16 Hp tractor with R1 tires. Turf damage was minimal. Ride was a bit rough. But now I use a ZTR. Much faster mowing, and no need to break out a push lawn mower for tough spots. However, a ZTR has trouble with wet or highly sloped conditions. I have to wait for a few days dry weather before I can use it. I now have a larger 50 Hp Mahindra for bush hogging and tree farm work. I do not mow my lawn with it.
   / scut ride comfort while mowing, R4 vs turf vs R14 #29
I’ve been mowing with my 3046r cab with R1 tires loaded and it rides a lot better than the r4’s did loaded. R4’s to me just felt bouncy the whole time. I had them on my first tractor as well and never liked the ride. My r1’s flex a lot better.
   / scut ride comfort while mowing, R4 vs turf vs R14 #30
I just swapped out my original R1s on my BX23 with Turf tires (at 18psi vs 20psi spec'ed) and my ride improved - glad I made the change.
2016 FORD TRANSIT PASSENGER VAN (A56129)
2016 FORD TRANSIT...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Deere 35G (A53314)
Deere 35G (A53314)
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
40' CONTAINER (A51244)
20716 (A55853)
20716 (A55853)
