Oil & Fuel Scratching my head after oil change
   / Scratching my head after oil change #1
bmiker
After changing the engine oil and filter on my 5740 three days ago I'm still cant figure out why it was 3 quarts over full. I let engine warm up pulled drain plug let it drain for over 1 hr. changer filter, refilled with 9.9 quarts of rotella 5 w 40 just like the owners manual says . Started engine turned it off checker oil was 3 quarts over full. Which I have not drained out so the dip stick shows to the full mark. Yes I double checked the amount of oil I used 2 1 gallons jugs and almost 2 quarts. PS this was the second oil change Ive done on this tractor didn't have this problem before. What am I missing ?? any ideals THANKS
   / Scratching my head after oil change #2
Did you open both drain plugs???
   / Scratching my head after oil change #3
I don't know about that model, but my B2710 had two drain plugs so you wouldn't drain it all out unless you removed both.
No I didn't I thought and think that each drain plug does the same thing . The reason for two is just encase you couldn't get to one like with different attachments I could be wrong ???
   / Scratching my head after oil change #5
Yep, you would be:D If ya look, there is a drive shaft down the middle of the oil pan!!
Thanks I'll will look.The book shows both plugs but I didn't see where it says to remove both.
   / Scratching my head after oil change #8
Sounds just like my B2710, so you certainly had to remove both plugs.
My L3940 is the same. I am not sure how the oil pump pickup works on these. It must pull from both sides I guess.
   / Scratching my head after oil change #9
How much did you drain out originaly, that would tell you how much you can put back. You have to open both drain plugs.
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
2014 Ford Escape SE (A56859)
2014 Ford Escape...
2006 APPA TL (A55787)
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
