Oil & Fuel Scratching my head after oil change
   / Scratching my head after oil change #1
bmiker
Member
After changing the engine oil and filter on my 5740 three days ago I'm still cant figure out why it was 3 quarts over full. I let engine warm up pulled drain plug let it drain for over 1 hr. changer filter, refilled with 9.9 quarts of rotella 5 w 40 just like the owners manual says . Started engine turned it off checker oil was 3 quarts over full. Which I have not drained out so the dip stick shows to the full mark. Yes I double checked the amount of oil I used 2 1 gallons jugs and almost 2 quarts. PS this was the second oil change Ive done on this tractor didn't have this problem before. What am I missing ?? any ideals THANKS
   / Scratching my head after oil change #2
Did you open both drain plugs???
   / Scratching my head after oil change #3
I don't know about that model, but my B2710 had two drain plugs so you wouldn't drain it all out unless you removed both.
No I didn't I thought and think that each drain plug does the same thing . The reason for two is just encase you couldn't get to one like with different attachments I could be wrong ???
   / Scratching my head after oil change #5
Yep, you would be:D If ya look, there is a drive shaft down the middle of the oil pan!!
Thanks I'll will look.The book shows both plugs but I didn't see where it says to remove both.
   / Scratching my head after oil change #8
Sounds just like my B2710, so you certainly had to remove both plugs.
My L3940 is the same. I am not sure how the oil pump pickup works on these. It must pull from both sides I guess.
   / Scratching my head after oil change #9
How much did you drain out originaly, that would tell you how much you can put back. You have to open both drain plugs.
skeleton / rock bucket (A56857)
skeleton / rock...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2022 Caterpillar 300.9D Mini Excavator (A55973)
2022 Caterpillar...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
