scratch build loader?
/ scratch build loader? #1
Groo
Platinum Member
I am kicking around the idea of doing a "scratch build" loader/snow plow/whatever of some sort; either articulated or 4 wheel steer.
I am heavily leaning towards a hydraulic drive with wheel motors so I don't have to mess with gears and driveshafts.
I am trying to work through some of the formulae to get a better idea of what sorts of components I would need to make a functional machine, so I can start virtual shopping.
I work with hydraulics, so that part wont be too tough, but I need to know stuff like suggested ground force?
for example, if I use wheel motors capable of 6250 in-lbs and stick on 30" tires, that gives me 417 lbs of force, assuming I am on 2 wheels while digging, 833 lbs of of digging force, or 1666lbs total peak potential pull.....I am guessing I would want more than that from a machine that will probably be over a ton completed. Is 1:1 pull what I should shoot for? higher? do I just pick a desired bucket size and work from there?
any idea what the commercial small loaders use for wheel motors?
Any reason to choose open center or closed center for the hydraulics? I know a variable displacement pump will be much more expensive than a solid Chinesium gear pump.
any engine suggestions? industrial? from a small car?
pros and cons of articulated vs 4 wheel steering (other than than how complicated it would be)? Seams like articulated would keep the turning tires out of the way of the loader mechanism, but be a bit less stable turning.
anything else to consider for this pipe dream that will likely never happen?
YouTube would be more for design ideas. I am trying to figure components capabilities and cost's at this point.
Thinking about fixed displacement vs. Variable displacement, I could get by with a much smaller engine and still get peak drive force and speed with a variable displacement.
For example, the first gear pump I considered would need 250 ft lbs of torque to make peak pressure. I'd need a V8 to make that. But a variable displacement would just shift to a smaller pump size when it bogs down, then become a bigger pump when I heading cross country.
/ scratch build loader? #4
What size and lift capacity?
Mine is a 3 cylinder 22hp diesel, 9 mph top speed:
Yours is a front deck mower with a loader added on in place of the mower deck, correct?
I was thinking 1-2,000lbs, maybe more depending on how the weight works out. I am looking at drive and tractive force at this point. Thinking more and more about possibly 6wd, but that would also require a more complex suspension, (steering would be just link to move it half as much as the other if articulated, or nothing if 4 wheel steer) so not 100% sure about that. with 4 tires, just solid mount 1 axle and pivot mount the other and all 4 will contact regardless of terrain within the limits of the pivot axle range. add a 3rd axle, and there needs to be some suspension to allow for 1 axle to be higher or lower than the plane of the other two.
Maybe what I really aught to do is help Dad get his next piece of equipment (he was thinking skid steer, but I am convincing him a small telehander would be better for him) and buy his CUT, that I've been driving and fixing for the last 30 years.
/ scratch build loader? #6
Correct.
The compact telehandler that I have is the most amazing machine that I have ever owned, and I have owned more tractors than I can remember. Show him this thread: http://www.tractorbynet.com/forums/...pact-telehandler-post3243370.html#post3243370
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
FORREST CITY ROLLING HARROW (A63291)
FORREST CITY...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
2019 Bobcat S450 Compact Wheel Loader Skid Steer (A61572)
2019 Bobcat S450...
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
