I love your box blade, and I'm really impressed with your fabrication skills. I will make two suggestions:
1. As others have suggested, commercial blades have reinforcement on the back wall to stiffen it. A piece of angle-iron welded across the top of the back, at least, but something along the bottom as others have suggested would also be good. On mine, the back wall has just been bent to a right-angle at the top, in a brake, but that's probably not something you can accomplish, especially after the fact.
2. The most obvious weak spot in your design is the central "down-tube" (that's what it would be on a bike) on the three-point frame. At the VERY least, you should rotate that piece ninety degrees along its long axis. Most of the stress on the blade will be trying to torque the back of the blade down and towards the front of the tractor, around the lower lift pins. This torque is opposed by that "down-tube", but as you can see, if you have that piece of stock flat, it's very weak in resisting that force, since it wants to bend along its flat direction, and is very stiff along its tall direction. On my box blade, there are actually two of that piece, running left and right of center, and they are oriented up-and-down, not flat. Alternatively, you could replace the piece of flat stock with a piece of tubing. If you do any of this, do it after welding the angle iron to the top of the back wall, since that'll change your measurements.
