scraper blade mess
/ scraper blade mess #1
deereman63
deere 2210
I have a six foot scraper blade and have just discovered that this thing can be lethal to a gravel drive. I thought i would pull in material that had worked to the outside during the winter.. The problem with this is that it is very difficult to get a level surface. By the time i had finished the driveway looked like the battle field at Verdun not some pride of surburbia. /forums/images/graemlins/shocked.gif2 problems I think
1) It is quite difficult to accurately control the lowering of the hitch. Any solutions to this?
2) there is to much play on such a wide blade. Next time i will remove the two extensions bringing the blade down to 4ft.
/ scraper blade mess #3
Putting skid shoes or gage wheels on the blade can make a HUGE difference from what I can see.
Running the blade backwards, so it is less aggressive is an option, but something to hold the blade up works even better in my limited experience... /forums/images/graemlins/smile.gif
/ scraper blade mess #4
Might try renting a rake for this kind of work.
Or, if the material isn't too much...or too heavy, just rake it by hand (of course, I've no idea of the length of your drive).
I normally push some gravel on to the lawn when I push snow. Some I rake by hand, some I just leave if it isn't clumped up.
/ scraper blade mess #5
What exactly are skid shoes? How do they attach to the blade? I'm curious because it looks like I'll be picking up a woods blade some time next week and I don't remember seeing that as an option.
/ scraper blade mess #6
I just graded mine yesterday. I use a rake, it works much better. The tines stir up more of the fines and such which will then pack better. I made multiple passes in the "normal" orientation, angled to pull material toward the center then a pass with no angle to distribute the center material. After all that I swiveled the rake around and did the same with the rake reversed. It's much better but I have some areas that desperately need more stone. That will have to wait until spring.
I have a blade also but found it doesn't work well at all for drive maintenance. I only use it for snow now /forums/images/graemlins/smile.gif
/ scraper blade mess #7
Yuo can only make a washboard surface with a tractor & a blade not angled and no gauge wheels. The mechanics force this outcome.
However, angle that wide blade as far as you can, run pu & down the driveway several times throwing the loose stuff to the middle, and you will come out level with a crown. Works great.
The key is to angle the blade - more is better.
With a flat (perpendicular) blade, as the tractor wheels go up & down over little bumps, so does the blade and makes things worse. With the angled blade, it will not follow the ripples, but actually level.
Spin the blade around & finish by using the back edge, fether the gravel out...
--->Paul
/ scraper blade mess #8
That's great advice from rambler. When I get to redoing my drive, I'll use that technique. I had to regrade a very shallow swale and couldn't rotate my 5' blade to max (but did have it at 15°) cuz I needed the wheels outside the ditch so I did 2 things: 1) I shortened the top link as far as it would go then 2) I cut 1" pipe 2" long for spacing the top of the blade assembly forward of the mounting plate to further decrease the shallow angle of entry into the dirt. Both mods worked a lot better than original.
Cheers!
/ scraper blade mess #9
I have also recently learned of the power a blade can have.TNT would be a nice feature,but not an option for me right now. The angle did help, but it is hard not to bury the blade on uneven ground. I use the blade mostly to break it all up and then go over it with a pulveriser to spread it out. You don't get the crown that way tho. I will just have to practice some more, maybe on someone elses drive LOL. /forums/images/graemlins/grin.gif
/ scraper blade mess #10
gauge wheels are the way to go. I have a landpride rake with flip-down blade and before I got the gauge wheels, driving down my gravel driveway was like a thrill ride...kids loved it.
/ scraper blade mess #11
" <font color="blue"> </font> spin it around and back blade <font color="blue"> </font> "
I agree with Brad, flip it around and back blade. It works for me. /forums/images/graemlins/wink.gif It seems you can go on and on buying attachments so I've had to control myself.
/ scraper blade mess #12
Im a total novice, and I've tried to understand your suggestions but not sure if I'm understanding correctly
my gravel road is pretty well compacted, and I have a very rocky base because of generaly rocky land, but I do have some small wash out areas on some edges of the road. I have a 5' box blade. My scraper blade is adjustable from 4-6 feet. Pulling it behind my Ford 640. What would be the best and most succesful way to attack this?
1. use the scarifiers on my box blade to somewhat rake up or loosen the gravel, and then use my scraper blade angled to crown to the center (should this also be in a "back blade" type setup?), then lightly back blade down the center to spread the crown.
2. Do the previous using only the 4-6 foot scraper blade without scarifiying.
3. As in number 1 above, but using only the box blade to do the grading?
2012 Dodge Grand Caravan (A62180)
2012 Dodge Grand...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63118)
2010 Kenworth T3...
Irrigation Pump/pump started up (A62183)
Irrigation...
2012 FREIGHTLINER CASCADIA 6X4 T/A DAYCAB TRUCK TRACTOR (A59910)
2012 FREIGHTLINER...
