Scraper blade for arena groomer
   / Scraper blade for arena groomer #1
gerard
Veteran Member
Syracuse NY
Kubota L2500DT w/FEL
Attached is a modification I made for my arena drag. The groomer has two sets of teeth (not in picture) that scarify the footing, then the spiked roller rolls it flat. The problem was we have sand footing and when it's wet it sticks to the spiked roller, building up until the spikes are covered, then the roller doesn't turn and leaves an irregular pattern behind it depending on the shape of the build up. I used some 1 1/2 square tube and some 3 inch flat stock, cut each piece to size and welded it in place. Now the sand gets scraped off by the blade and doesn't build up. About a 6 hour project.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Tanker Trailer (A59230)
Tanker Trailer...
MASSAGE CHAIR (A58214)
