Driveway weed clearing
/ Driveway weed clearing #61
Sounds like the backpack sprayer needs seals kit- it’s a 5 minute repair
We use RM43 and it kills everything for a year
RM43 is just glyphosate (roundup) with a little dash of imazapyr. Which works as a pre-emergent.
43% GLY
0.78% imazapyr
If you are using very little per year....RM43 is okay. But if you use it ALOT.....ita actually alot cheaper to buy those two chemicals separately.
RM43 cost ~$60/gallon.
You can buy 2.5gal of generic Glyphosate for about the same. And imazapyr 53% can be bought for ~$1.50/ounce
Take 1 ounce of 53% imazapyr and mid with 1 gallon of Glyphosate concentrate and you just made RM43 for about half the cost.
The catch is you have to buy a quart of imazapyr. So enough to make 32 gallons of RM43 concentrate. So again....small quantities isnt really worth it. But if you are spraying several gallons of the stuff every year....its worth a look. OR......if you just want to use it as a preventative....IE you dont have any green vegetation showing....you are wasting time and money spraying glyphosate.
Side note.....The mojave 70eg that was mentioned earlier....is a mix of imazapyr and diuron. Diuron is another fairly power pre-emergent that complements the imazapyr very well. And the two of them together in mojave 70eg work alot better than RM43
/ Driveway weed clearing #62
Years ago the neighbor got a 5 gal container of herbicide from a guy that works for the railroad. I know it kills everything on the fence row for a LONG time. Does the RR use more potent stuff than what the normal public can get?
/ Driveway weed clearing #63
, I just spray the weeds I see. Then I go back a few weeks later and spray the ones I miss
This is also how I spray. No need to spray areas with no weeds showing as it's a waste of material, glyphosate only kills what's growing not stuff that hasn't grown.
/ Driveway weed clearing #64
A person with a herbicide licence can get stronger stuff than a typical person can get. I have seen the stuff kill 16in 40ft tall pine trees. But I think that's a bit extreme for a driveway.
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
SDLanch SDLGC80 Electric Golf Cart (A62183)
SDLanch SDLGC80...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
John Deere 1418 Bush Hog (A64047)
John Deere 1418...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
