Buying Advice Scag is crap Should have bought a Kubota ZTR
   / Scag is crap Should have bought a Kubota ZTR #41
I had a Dixon and it was a good mower but it was literally worn out in about 5 years of mowing. In it's defense it was hard and heavy mowing, it would have been perfect for a suburban yard. Went with a Kubota ZD21 diesel 12 years ago and We are still using it. Can't comment on the other makes as I have not used them.
   / Scag is crap Should have bought a Kubota ZTR #43
I thought that my JD 997 was the best :hissyfit:
I've got the best of the best, a Kubota ZD323 with R4's, can mow field grass in pooled water.
   / Scag is crap Should have bought a Kubota ZTR #44
so the darned thing swims?
   / Scag is crap Should have bought a Kubota ZTR #46
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=377835"/>
I was wondering about those tires... do they Mark the ground up? Would I piss off any account holders?
Ask them WHY they took the new carb apart? What was the reasoning behind doing so? They or you or both don't see how the new carb was the problem? They don't know what they did, but it is running?:confused2: As opposed to what? - not running? ? is: is it fixed?!
As I said, they could not or would not tell me what they did to actually make the engine run.
It is running now.
   / Scag is crap Should have bought a Kubota ZTR #49
It is running now.
OK, and good. Seems evident they screwed up when doing the carb replacement. I'm glad it's running for you now. I asked what I did to get things focused on the last thing they touched to solve the problem. Hopefully it'll be trouble free going forward.
   / Scag is crap Should have bought a Kubota ZTR #50
It is running now.
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
Electric Horseless Carriage (A57453)
Electric Horseless...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
