Buying Advice Scag is crap Should have bought a Kubota ZTR
   / Scag is crap Should have bought a Kubota ZTR #41
I had a Dixon and it was a good mower but it was literally worn out in about 5 years of mowing. In it's defense it was hard and heavy mowing, it would have been perfect for a suburban yard. Went with a Kubota ZD21 diesel 12 years ago and We are still using it. Can't comment on the other makes as I have not used them.
   / Scag is crap Should have bought a Kubota ZTR #43
I thought that my JD 997 was the best :hissyfit:
I've got the best of the best, a Kubota ZD323 with R4's, can mow field grass in pooled water.
   / Scag is crap Should have bought a Kubota ZTR #44
so the darned thing swims?
   / Scag is crap Should have bought a Kubota ZTR #46
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=377835"/>
I was wondering about those tires... do they Mark the ground up? Would I piss off any account holders?
Ask them WHY they took the new carb apart? What was the reasoning behind doing so? They or you or both don't see how the new carb was the problem? They don't know what they did, but it is running?:confused2: As opposed to what? - not running? ? is: is it fixed?!
As I said, they could not or would not tell me what they did to actually make the engine run.
It is running now.
   / Scag is crap Should have bought a Kubota ZTR #49
It is running now.
OK, and good. Seems evident they screwed up when doing the carb replacement. I'm glad it's running for you now. I asked what I did to get things focused on the last thing they touched to solve the problem. Hopefully it'll be trouble free going forward.
   / Scag is crap Should have bought a Kubota ZTR #50
It is running now.
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC-65 65ft Insulated Bucket Truck (A56858)
2017 Ford F-750...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
2008 TEREX TRAILER LIGHT TOWER (A58214)
2008 TEREX TRAILER...
