SC2400 jumps to high range
   / SC2400 jumps to high range #11
Merely an observation here. temmert has not been seen on this forum since Sep 2020. Also his original post had said he has an SC2400. That is a tractor and loader (usually equipped) from the factory. An SC2450 has the backhoe attachment. My SC2450 does not have filled tires but as a 2450, is backhoe equipped.
blacktruck,l oops, didn't see his forum date ,( not enough coffee ) you are correct on the models, I was just checking as some people sometimes will leave out all the info, for your info, there is a cure for this issue
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2017 HAMM HD+140I DBL DRUM ROLLER (A60429)
2017 HAMM HD+140I...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2026 tilt trailer (A56859)
2026 tilt trailer...
