Sc2400 bleeding transmission
/ Sc2400 bleeding transmission #1
FLruss
CCY SC2400
I have a 2009 sc2400. The manual says to bleed the transition when changing the transmission fluid or filter, however it does not provide instructions for bleeding it. How do I bleed the transmission,
/ Sc2400 bleeding transmission #2
I'm not sure if you found an answer to your question but I think what the manual is refering to is the vent valve which is number 14 in the figure in the Page 72 pdf. I would assume you just open the valve to make sure that the fluid can flow freely.
  • Page 72 from Sc2400 parts manual Transaxle.pdf
  • Page 73 from Sc2400 parts manual Transaxle.pdf
/ Sc2400 bleeding transmission #3
Has anybody ever done this on the SC2400? Can't find anything online and the manual is vague like the op mentioned..
