Sawmill
/ Sawmill #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I could not resist to come back to my old stomping ground to show off :D
First, this is what it does:
/ Sawmill
It is based on an I beam I got for free and the whole idea is taken from Logosol.
/ Sawmill
Log moves up with 1" ACME rods.
The log dogs I may need to change or improve, but it works for now.
/ Sawmill
Cheap rulers help setup the thickness, 1 3/8" move up gets me 1" board.
/ Sawmill
24" bar with ripping chain will need an end support, it shakes bit too much.
I tried to use whole 372XP clutch assembly, but it would slip on slow down - this is the outer clitch piece welded to a spindle. It gives me the option to replace the chain sprocket rim as needed.
/ Sawmill
The whole electrical setup has to be updated, also the oil delivery is lacking - gravity feed only now - probably will have to get some kind of an oil pump.
/ Sawmill #8
I like it. I'm assuming you have a ripping chain on there. How is the chain oiled? How many HP motor?
/ Sawmill
The motor is 6hp and yes, using ripping chain.
Oiled is gravity fed and the bar has extended hole to get the oil to the chain, but I think it needs more pressure than gravity to lube better.
/ Sawmill
Thank you, gentlemen :)
The motor is 3450 rpms, pulleys get it to around 8500 but that's open for experimentation too. Seems like lower speed prolongs the life of the bar and chain. Also the blade cuts away from the beam - shavings do not fly in my face and also the chain gets lubricated right before cutting but I was told that using it this way puts too much strain on the nose sprocket of the bar.
I have access to downed trees at the place I hunt, more than I am willing to wrestle with :)
/ Sawmill #15
You'd have no problem with an overhead support bar. Aquarium pump should work for oil. Run two drip points. One right on the sprocket through a larger hole drilled in the grease point. Pull the sprocket and braze on a fitting?
/ Sawmill
Yes, Egon, seems like I am overthinking it. Did some research and oil dripping on the chain is used in most cases, no need to run it through the oiling port in the bar since the saw is always horizontal.
/ Sawmill #17
Remember those spring loaded grease caps on equipment? One of those would also work on the sprocket.
/ Sawmill #18
Are you running a standard chain saw chain?
I believe they use a different chain on the Alaska Mill type saws but I am not sure.
If you haven't found- www.forestyforum.com
You should check it out, all about saw mills.
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Madvac CS500 Sweeper (A61166)
Madvac CS500...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61307)
2006 Heil Tanker...
2013 BMW X5 xDrive50i AWD SUV (A61569)
2013 BMW X5...
Rhino DKIN 3pt Backhoe (A60462)
Rhino DKIN 3pt...
