Sawmill
/ Sawmill #61
I have a bunch of 70 year old White Pine and just bought a used sawmill, never used one before in my life but I never liked pine because the bugs get into it and make a sure mess at least here in Vermont. This guy says White Pine is the best for framing. How does one keep the grubs from chewing up my new timber frame woodshed?
White Pine is the Best Wood For Timber Framing... - YouTube
I like white pine as well. Southern Pine beetle kills white pines (don't know if they are an issue in Vermont), but they only damage a small layer just under the bark. They do carry a fungus with them that causes a blue stain to the wood, which lowers it's value for finish lumber, but makes no difference in framing lumber.
The "saw worm" that you often see in white pine as a grub that makes large holes in the wood, is the result of a of an egg laid by some variety (there are several) of long horned beetle.
Fairly ugly looking critter:
The egg hatches to a larvae stage grub that eats pine to Swiss cheese. You can actually hear them crunching away on the logs and see the sawdust being pushed out their holes.
The trick to avoiding this is saw the logs BEFORE the beetle gets a chance to lay the eggs in the bark. They will not lay on lumber, just on whole logs that are downed/dead. The don't attack live trees either. But they will move in on a tree you cut within a few days when they are active. Tree must give off some kind of scent or something they recognize as "cut tree" or "dead tree", because I've cut trees, come back few weeks later to buck into logs, and have found them already eating. Eggs must hatch almost immediately too.
IF you cut pine in the winter, the logs are OK until the weather warms and the beetles are active. Rest of the year, you need to saw, or debark, ASAP to prevent damage. Once the larvae (grub) are in the wood, they will continue to eat (though not as bad as undisturbed logs)....so the trick is to get them sawed BEFORE the beetle lays it's eggs and you'll have no grub damage.
Powder post beetles are another problem, but I've never seen them in pine....they seem to prefer hardwoods like oak/hickory, and often do their damage AFTER the logs are sawed into lumber. The trick to beating them is a high temperature dry kiln fore the damage is done, or it's possible to spray insecticide on lumber stacked for air drying, as well as the ground immediately around it.
/ Sawmill #63
I love EWP for trim and finish work -- we used truckloads of rough sawn EWP when building my house. Not expensive but looks great. People consider it a cheap wood but when finished right it looks beautiful to me. I have a couple on my property and will be sure to saw them if they ever need to come down, or fall in a storm.
For framing, southern yellow pine (SYP) is significantly better than EWP, with about 1.6-1.7x higher strength. Even better than Doug Fir. The main benefit is that you can get away with smaller posts and beams, which makes construction easier. I don't know if that was ever mentioned in that video (I only watched the first portion) but it should have been.
/ Sawmill #64
Guy in the video is in Michigan, where I'd guess SYP doesn't grow. But you're right, it's a much stronger lumber. We have a small amount up this way, but not much.....a 'long leaf' pine, but probably a variant on true SYP. We also have a lot of slash/black/Va pine, (goes by a lot of names) a short 'leaf' pine that isn't much good for anything.
/ Sawmill #65
Hemlock is often preferred around here for framing. Just get it nailed up while its still some green so it won't twist or split on you.
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
