sawmill time
/ sawmill time #1
Sonny580
Central Illinois
several kinds and sizes
Got started on the log pile today,--got a few pix. I have only small logs but it's for my personal use.
I cut slow due to 4 spinal surgeries, but I can't give up!--Besides I like logging and making boards, when I'm not in the garden! thanks; sonny580
/ sawmill time
You one one of them 1946'ers?? --so am I!
Back in mid 80's, I had a new belsaw M-14 pto drive and did cut a lit of logs for many years with it!--several years ago it and other stuff got stolen, (junked) and I finally got this little band mill to cut small logs for my own use! thanks; sonny580
/ sawmill time #5
Awesome!! I just got an older hudson, need to level and then in the spring I can start cutting.
/ sawmill time
Nuttin' more satisfying than makin' dust fly and getting interesting lumber!--I saw a few logs just to see the grain inside.--some is odd and finishes up super! thanks; sonny580
/ sawmill time #8
I got some poor quality pine logs (too many limbs/knots) and used them to dust off my HF mill last month.
It's fun to make your own boards!!
The HF mill is a cheap way to get into milling if anyone is considering it.
The way it comes it will cut a 9' 6" board but I made an extension so I can cut 16' boards.
/ sawmill time #9
I saw a little from time to time also for projects around the farm. Here sawing a 30' beam on a 20' Woodmizer. :D
enhance
/ sawmill time #10
I do a little milling too, here's a 20' 6" American Blk. Cherry on the mill,
SR
/ sawmill time
Steve, the boards in the pic. are cherry and maple. You guys have some expensive mills!! NICE!!!--- mine is a little Timber Tuff mill. It does fine for my logs, and if I run into bigger log, I just skin it down with the 36" Granberg chain saw mill until it fits the band saw.
I do have a bit of walnut,and hackberry to cut.--Also want to do a big straight hedge tree that we have at the farm.--hedge finishes up to a golden orange as it ages! thanks; sonny580
/ sawmill time #12
SR
Man, what a pretty log....very little taper and dang near straight as an arrow.....amazing for a 20' cherry log here. What use will you put 20' cherry lumber to Rob ? I usually cut my cabinet/furniture stuff into 8-12' lengths, and just saw framing material in longer lengths.
/ sawmill time #13
Yeaaa, I got a pretty good tally out of THAT log,
and much of it was clear,
One of the reasons I cut the log out so long is, I had planned to use it in a room that is 18' long and the trim would be full length... AND I could always cut some of it down shorter to build the cabinets out of...
SR
/ sawmill time #14
One of the reasons I cut my "good" stuff in 12' or less is my dry kiln room won't handle but 13' lengths.
enhance
/ sawmill time
KILN??!!!! Oh come on now!!! WOW!---You got it made!!--always was interested in a kiln.--care to divulge any info on it???? thanks; sonny580
/ sawmill time #16
Just a spare room in my shop....8x13, 7' ceiling. Insulated, inside is OSB with a couple coats of aluminum mobile home roof coating to seal moisture inside. An OLD (use R-12, not R-22) window air conditioner on a shelf inside. Heat off the AC raises the room temp to about 130 max, moisture comes off as the temp raises, hits the cold coil and drips in a bucket ( basic dehumidification process).
I air dry my lumber down to about 18-20% moisture (year or more on sticks in dry), then move it into the kiln to take it down to 6-8% for furniture/cabinet projects.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A68183)
2023 Caterpillar...
PALLET OF RAMPS (A68842)
PALLET OF RAMPS...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
