sawed up some amazing crotch walnut last week (video)
   / sawed up some amazing crotch walnut last week (video) #1
123maxbars
Kubota B3200
Last week I finally started sawing up my walnut log inventory. I have about 100 walnut logs ready to saw.
This one turned out pretty well with some amazing crotch figure. It was a yard tree also, but luckily
did not have any metal, I videoed the days sawing. Thought you guys would like to see,
THIS WALNUT LOG HAD A SURPRISE UNDER ITS BARK - YouTube
   / sawed up some amazing crotch walnut last week (video) #2
You made some beautiful lumber - you use it to construct or do you sell it. BTW - where are you located that you have such nice large walnut trees?
I helped my neighbor pull pine trees out of this place and prep them for a borrowed lumber mill. Not as big - nor as fancy as yours. The initial adjustment you make are all manual - when the unit starts cutting, then its operation is automatic - correct. As you move down the log - you reach up every so often and give the blade a "squirt of water" - right.
My, OH, my - - that is truly some beautiful lumber. Nice table top, hearth & fireplace mantle material.
   / sawed up some amazing crotch walnut last week (video) #4
...you reach up every so often and give the blade a "squirt of water" - right....
FWIW...it looks to me like he is adjusting the flow...when cutting most logs there should be a constant flow of lube water (H2O+ surface tension cutting additive like liquid soap etc.) on the blade...they are usually gravity fed from a reservoir mounted on top of the carriage.
   / sawed up some amazing crotch walnut last week (video) #5
Nice, what do your buyers make with them?
   / sawed up some amazing crotch walnut last week (video) #6
great post
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
