sawed up some amazing crotch walnut last week (video)
   / sawed up some amazing crotch walnut last week (video) #1
123maxbars
Kubota B3200
Last week I finally started sawing up my walnut log inventory. I have about 100 walnut logs ready to saw.
This one turned out pretty well with some amazing crotch figure. It was a yard tree also, but luckily
did not have any metal, I videoed the days sawing. Thought you guys would like to see,
THIS WALNUT LOG HAD A SURPRISE UNDER ITS BARK - YouTube
   / sawed up some amazing crotch walnut last week (video) #2
You made some beautiful lumber - you use it to construct or do you sell it. BTW - where are you located that you have such nice large walnut trees?
I helped my neighbor pull pine trees out of this place and prep them for a borrowed lumber mill. Not as big - nor as fancy as yours. The initial adjustment you make are all manual - when the unit starts cutting, then its operation is automatic - correct. As you move down the log - you reach up every so often and give the blade a "squirt of water" - right.
My, OH, my - - that is truly some beautiful lumber. Nice table top, hearth & fireplace mantle material.
   / sawed up some amazing crotch walnut last week (video) #4
...you reach up every so often and give the blade a "squirt of water" - right....
FWIW...it looks to me like he is adjusting the flow...when cutting most logs there should be a constant flow of lube water (H2O+ surface tension cutting additive like liquid soap etc.) on the blade...they are usually gravity fed from a reservoir mounted on top of the carriage.
   / sawed up some amazing crotch walnut last week (video) #5
Nice, what do your buyers make with them?
   / sawed up some amazing crotch walnut last week (video) #6
great post
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
3in Poly Pipe (A49461)
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
PALLET OF (2) THERMOKING TRIPAC UNITS (A50854)
PALLET OF (2)...
