sawed up some amazing crotch walnut last week (video)
   / sawed up some amazing crotch walnut last week (video) #1
123maxbars
Kubota B3200
Last week I finally started sawing up my walnut log inventory. I have about 100 walnut logs ready to saw.
This one turned out pretty well with some amazing crotch figure. It was a yard tree also, but luckily
did not have any metal, I videoed the days sawing. Thought you guys would like to see,
THIS WALNUT LOG HAD A SURPRISE UNDER ITS BARK - YouTube
   / sawed up some amazing crotch walnut last week (video) #2
You made some beautiful lumber - you use it to construct or do you sell it. BTW - where are you located that you have such nice large walnut trees?
I helped my neighbor pull pine trees out of this place and prep them for a borrowed lumber mill. Not as big - nor as fancy as yours. The initial adjustment you make are all manual - when the unit starts cutting, then its operation is automatic - correct. As you move down the log - you reach up every so often and give the blade a "squirt of water" - right.
My, OH, my - - that is truly some beautiful lumber. Nice table top, hearth & fireplace mantle material.
   / sawed up some amazing crotch walnut last week (video) #4
...you reach up every so often and give the blade a "squirt of water" - right....
FWIW...it looks to me like he is adjusting the flow...when cutting most logs there should be a constant flow of lube water (H2O+ surface tension cutting additive like liquid soap etc.) on the blade...they are usually gravity fed from a reservoir mounted on top of the carriage.
   / sawed up some amazing crotch walnut last week (video) #5
Nice, what do your buyers make with them?
   / sawed up some amazing crotch walnut last week (video) #6
great post
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2005 Ford F650 SVI Crew Cab Fire Truck (A49461)
2005 Ford F650 SVI...
