Saving $ on electric filler pump (ideas?)
/ Saving $ on electric filler pump (ideas?) #21
</font><font color="blue" class="small">( I found a rotary timer 0-30mins on Ebay for $2, so it should be here soon. Once I get it, I'll see what circuit and components will work best.)</font>
Verify the contact rating on the timer switch is sufficient for the
amperage draw of the pump motor.
</font><font color="blue" class="small">( Dumb question, though. If the trickle charger is left attached to the battery, as is the line to the rotary switch, then to the motor, will the high current draw harm the trickle charger? Is there some component I have to add to protect the trickle charger during the usage of the pump?)</font>
Most likely not an issue for a mass-market trickle charger which
is designed to be placed across a battery of arbitrary charge state.
The trickle charger will be internally current limited. Then again
you won't be placing as large a load on the battery compared to
cranking an engine starter.
/ Saving $ on electric filler pump (ideas?) #22
</font><font color="blue" class="small">( If the charger has a full wave bridge rectifier neither the pump motor nor
you will notice the difference between using it vs. a 12 battery.
)</font>
Keep in mind that a full wave bridge still puts out 'unfiltered' dc, as it is chopping and flopping. Makes a decent positive waveform on a scope.. takes a hit on average power a bit when under load.
</font><font color="blue" class="small">( One point of caution is the running amperage draw of pumps in this class
is around 20A. So you may want to verify the charger/transformer can supply
this for at least the intermittent basis the pump will be running. It would
also be a good idea to size for current draw on both motor startup and
when dead-headed with the relief valve bypassing. )</font>
That's why I sugested a charger across a battery... Even an atv battery.. The battery will more than adequate to source the needed current.
</font><font color="blue" class="small">( You may find it simpler to use an inexpensive
30A 12V automotive relay )</font>
I agree.. a sealed relay is the way to go...
Soundguy
/ Saving $ on electric filler pump (ideas?) #23
</font><font color="blue" class="small">( Keep in mind that a full wave bridge still puts out 'unfiltered' dc, as it is chopping and flopping. Makes a decent positive waveform on a scope.. takes a hit on average power a bit when under load.)</font>
The motor speed is proportional to the average voltage seen by the motor.
The voltage output of common battery chargers will peak in excess of
12V being 12V RMS. If full wave rectified this will still have a 120Hz
component, however this is will not impact motor speed/torque.
/ Saving $ on electric filler pump (ideas?) #24
</font><font color="blue" class="small">( If full wave rectified this will still have a 120Hz
)</font>
Current will still be an issue. Even on a hih output charger.. or one with a 'starter setting'.. I've noticed that the high current setting on many of them are at quite a bit under 12v.. more like 8-10v to provide the 'stated' current under load on the label. For instance.. the 50 amp start setting on my charger, with volt meter across the battery will drop to 10v under light load ( lawnmower ).. and 8v on my antique tractor.. The battery sources more of the current, and faster providing it is good and charged.. lot easier than generating it ( just use the stored energy instead.. )
Soundguy
/ Saving $ on electric filler pump (ideas?) #25
I use a 12v deep-cycle marine battery.. they have the regular battery terminals.. plus the bolt-on connections as well. The pump uses the bolt-on connectors.. and when the battery runs down.. I just hook up the battery charger on the terminals.
/ Saving $ on electric filler pump (ideas?) #26
</font><font color="blue" class="small">( Current will still be an issue. Even on a hih output charger.. or one with a 'starter setting'.. I've noticed that the high current setting on many of them are at quite a bit under 12v.. more like 8-10v to provide the 'stated' current under load on the label.)</font>
Quite possibly for an inexpensive charger. Voltage drop
under increased current draw is primarily an issue of internal
resistance in both cases of transformer and battery, with
the battery having additional limitations as seen by Peukerts
Effect, etc.. However on any 'charge' setting the voltage
output must be greater than the series cell voltage or the
battery will not charge.
Subject to available ampacity, discharge cycle depth/draw/duration
a battery makes for a fine solution to power the pump under
discussion. My first choice would be the one in the tractor as
it is already there complete with it's own charging system as
well as showing up when the tractor needs to be fueled. It also
has the poetic property where if it can't power the transfer pump
you really don't need more fuel in the tank.
/ Saving $ on electric filler pump (ideas?) #27
</font><font color="blue" class="small">( However on any 'charge' setting the voltage
)</font>
That's a real non-issue here, since the original idea was to run the pump just off the battery charger.. with NO battery in parallel. In that case there is -NO- charging occouring.. the charger is simply an unfiltered dc power supply that may or may not offere sufficient voltage/current to power the pump acceptably when under heavy load. That's why I suggested a battery in parallel in the first place. Undoubtedly with the battery in parallel footing the bulk of the load, charging and voltage drop will not be an issue.. unless the pumps current consumption exceeds that of the battery and charger's combined output.
I also like the idea of powering the rig from the tractor system.. say like from a cig-lighter plug. I mounted one under my tractors hood, directly across the battery.. for tire pumps and inverters and such.
I think the original poster didn't want the electrical connection outside though...
In any case.. he has tons of options now.
Soundguy
/ Saving $ on electric filler pump (ideas?) #28
</font><font color="blue" class="small">( <font color="red">However on any 'charge' setting the voltage
battery will not charge.</font>
That's a real non-issue here, since the original idea was to run the pump just off the battery charger.. with NO battery in parallel.)</font>
The point was not to charge a non-existent battery but to
illustrate the charger in 'charge' mode would need to be
capable of delivering greater than battery voltage at its
rated charge current. Otherwise it would be unable to charge
'a battery'. Thus this equivalent charger-supplied voltage and
current would be available to power the pump with no battery
present.
/ Saving $ on electric filler pump (ideas?) #29
</font><font color="blue" class="small">( The point was not to charge a non-existent battery but to
present.
)</font>
Yes.. and I was pointing out that a charger capable of handling a high enough continous charge current to run a decent pump is going to be a lot more expensive than a cheapo battery and float charger...
Looking at the small fuel transfer pump at work on the back of the mechanics truck.. it needs 7-8 amps... the larger pump on our 500 gallon tank wants 10-12 amps
While my cheapo 1.5 amp battery charger was 10 bucks.. my 2/10/50 was 69 bucks.... ( decent brand.. not a chineese special... has a meter, safety features, and float position /auto shutoff when in 2 amp mode)
A 29.99 battery from wally-mart and a 10 buck charger will run a decent pump way better than a charger you could get for 39.99... That's the point I'm trying to make... Not that it isn't feasable.. just that it isn't cheaper to do it that way..
Soundguy
/ Saving $ on electric filler pump (ideas?) #30
</font><font color="blue" class="small">( .. just that it isn't cheaper to do it that way.. )</font>
If cost is a primary concern another possibility is a cast-off
AT/ATX PC power supply -- many of which can provide
in excess of 20A at 12V. Some experimentation may be needed
as a few designs behave poorly if the 5V output is unloaded.
/ Saving $ on electric filler pump (ideas?) #31
You can put a cap on he output of the charger to smooth out the pulsed DC. A 35 volt 4700 micro farad cap would work. I did this to a batt charger 15 years ago to use as a power supply for sensitive peak charger.
CTyler,
[A 35 volt 4700 micro farad cap would work]
Are you sure about that? If so, I could connect and mount one to one of the leads from my timer, right?
Thanks to all so far for the input. Lots of good ideas.
-JC
/ Saving $ on electric filler pump (ideas?) #33
I went and looked at the manual for recomendation and it says 25 volt 4700 micro farad. Any voltage above that will work fine. The max amp draw for the peak charger is 10 amps. This will smooth it out but at higher amp draws a larger cap would smooth it
out even more.
Basically it takes the pulsed DC, looks like a square wave on a scope _-_-_-_ and makes it more of a modified saw tooth shape_/-\_/-\_. The cap discharges and provides current between pulses. Can't do any justice to the wave forms on the keyboard, but you get the idea. The larger the cap the more current its able to store to a point.
To add.....
This would work ok however if I were doing it I'd get a $18 lawn tractor batt and use that as has been suggested. That way I don't have to find the charger every time and drag a cord over there.
/ Saving $ on electric filler pump (ideas?) #34
How much differance in price between the 110 volt and 12 volt unit did you say? I am beginning to think that this might have been false economy...
/ Saving $ on electric filler pump (ideas?) #35
Ran into a similar problem on Sunday. Had hay to rake and bale but tractor was low on fuel, so pulled it up to the fuel tank. No fuel came out of the nozzle on my gravity feed fuel tank /forums/images/graemlins/shocked.gif. Darn thing is empty /forums/images/graemlins/frown.gif.
Hmmm...what was that thread I read on TBN? Don't have an electric pump so I grabbed a hand crank pump out of the garage and stuck it in the 500 gallon Fuel Oil tank that feeds our furnace. /forums/images/graemlins/laugh.gif
My arm was tired by the time I finished the first 5 gallon jug /forums/images/graemlins/crazy.gif, and with 3 more jugs to go I improvised. Took the nut and handle off the pump, found a pipe fitting that threaded on the shaft, put a bolt thru the fitting with a nut on the backside...added my Dewalt 18volt drill to the combination and I was in business. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Got thinking about the "anti-theft" value afforded by the removal of the drill and decided I came up with a novel idea that I should share with my friends here on TBN!
BTW...if you get all excited when you come up with what you think is a great idea...don't show your wife. At least not if she is the one responsible for paying for the heating fuel /forums/images/graemlins/shocked.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif.
/ Saving $ on electric filler pump (ideas?) #36
Using a capacitor to filter DC has it's limitations. Under high load situations.. there simply won't be enough stored energy in the cap to filter out the troughs and keep a steady DC line.
On the other hand.. a motor running doesn't need pure clean DC like oh.. say.. a logic circuit does.
If you were running into emi nois on a radio nerby I would also go with a L or Pi filter.. but then.. we are getting into a 60 dollar fix.. and the original poster wanted a cheapy soloution...
Again... hard to get by that cheapy battery and flot charger idea...
Soundguy
/ Saving $ on electric filler pump (ideas?) #37
After replacing a few of those batteries in coming years, the sweetness of the savings will become more sour than the original cost of a 110 volt unit. I have a 110 volt unit for the past 20 years and it still works like new. I also have a spare unit that I have never used and I am tired of moving it around the garage. Anyone close to MA/CT/RI border that needs one can purchase it reasonably from me. I believe it to be too heavy to ship any distance because of shipping costs today, but it might be worthwhile for someone that has a need for a unit like this.
/ Saving $ on electric filler pump (ideas?) #38
I will agree that if you figure in long term expense, the 12v unit will be more expensive if it uses its own battery. I didn't get the idea that this was a long term deal.. but more of a simple 'rig' for fuel.
Of course he could eliminate the redundant battery and power it off the tractor as another poster had sugested. Something as simple as a cig lighter hookup.. etc
Soundguy
AIR DUCT (A60432)
AIR DUCT (A60432)
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
24in Hydraulic Auger Skid Steer Attachment (A59228)
24in Hydraulic...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
