Saving electricity
   / Saving electricity #11
We replaced our 1980's fridge a few months ago and saw an immediate 15 to 20 dollar drop in our monthly bill. I figure that fridge will pay for itself in 3 to 4 years; sooner if rates go up.
Longer term plans include replacing the sump pump with a gravity drain. Last year it was common for that pump to run for 3 minutes every 8 to 10 minutes, for months at a time, due to the near monsoon weather we had. Buy digging a trench from the sump to the nearby intermittant creek, I can have a gravity drain. I will install a holding tank, mid run, so I can clean out the lines and put some critter screens in, just incase anyone comes a callin'.
This is all part of my master plan to justify buying a 'hoe with The Plant Manager. I did a similar cost benefit analysis before buying a welder generator, selling the benefits of being able to preserve all the food she keeps in the storage freezer and being able to stay in the house, keep warm and enjoy a hot shower. She was critical of this analysis after I bought it, but losing power for 6 days in August and 5 days in October convinced her that the Commisar of Central Planning was not blowing smoke.
"Wall Warts" (plug-in small battery chargers) are another source of constant demand. Try to find a way to eliminate them or at least control their eating habits.
   / Saving electricity #12
Anyone else wonder if maybe the power panel wasn't the only thing with loose screws :confused2:??? No dis-respect intended.
Loose connections can/will cause overheating, and perhaps a fire, particularly where there's a heavier current draw... and perhaps cause what-ever is on that circuit to run in-efficiently.
for sure, loose screws are a safety issue. (no pun intended)
Pete
I have personally seens hundreds and repaired hundreds of meter bases where either line or load wire burnt the terminals off the backside of an electric meter. If you own an older home and made upgrades, the load increases thru the meter. Think of the meter as a fuse link. Those connection inside that base should be inspected and tightened each time a major elctrical item is added to the home.
Contractors cutting corners on cost will install aluminum wire instead of copper.And yes I've seen fires too. Aluminum expands and contracts badly thus causing a loose connection in the breaker panel or meter base. Aluminum forms aluminum oxide around the wire thus causing the wire to get hot. Usually a electrical grease is put of the wire to prevent this corrosion. Alum Oxide is the same material spark plug insolators are made from. Get the idea.
As stated loose screw can steal from you. As that wire is heating up consuming energy, the home owner never sees it, untill it's too late and in need of a costly repair. Robert
   / Saving electricity #13
To "celebrate" our province slamming us with ANOTHER round of electricity rate increases today (latest excuse - "Gee, this smart meter system is expensive to put in" :confused2:), decided to start this...
I just checked the freezer on our kitchen fridge to make sure that the switch for the door heaters (for condensation in humid weather) was switched OFF.
Other than throwing the main disconnect, and going off grid, what are your tips for saving electricity ?
Rgds, D.
Dave,
As a fellow Ontarian, I'm in the same boat. Are you with HydroOne or another provider? HydroOne sends out pamphlets with your bill just about every month and great coupons for energy saving devices at least a couple times a year. Really, follow what they're saying and used the coupons. Other than that, eliminate phantom loads.
Are you on a smart meter yet? We have the chart on the inside of one of our kitchen cabinet doors and refer to it as needed. Put the dishwasher, washing machine, dryer etc on during low, off peak periods. Put a timer on your water heater if it's still electric, you probably don't need hot water all day and almost definitely not all night.
I have been working at it over the past 6 years, and I'll keep going. It doesn't make sense to put $14K worth of new windows and doors in to save $5/month on your electricity bill, but as you need to replace things, do it in a way that reduces your consumption, it's only going to get worse.
Finally, regardless of what you think of the fit program (I'm guessing from your post, you're not a big Dalton fan), take advantage of it, even at the now reduced rates. I tried, but was late getting to the party and they said my area is over capacity, but it's a great program from the making money stance. Welcome to microFIT | Ontario Power Authority
   / Saving electricity #14
Get a P3 International P4400 Kill A Watt Electricity Usage Monitor or similar.
It settles arguments and lets you know what's a power pig.
Make sure lights are OFF and put a master switch/ups on your entertainment center so you can effectively unplug everything at once.
Make it easy for all members of the household to use.
Stop using the computer.
   / Saving electricity #15
1. Energy Star appliances -- if you are contemplating new ones anytime in the future.
2. Anything remote controlled (TV, Sat/cable box, VCR, DVD, stereo, etc) is never really OFF unless you remove the power. Try using some switched outlets or build a switched outlet box/power cord for these things and turn them off completely when not in use.
3. Those "wall wart" chargers for cell phones, laptops, i-pads, etc., again, are using phantom amounts of energy when the devise is not actually plugged in and being charged.
4. Extra freezer/refrigerator in the garage, workshop or barn -- do you really need it? I know, I like my drinks cold and like having a place to put that extra meat and ice cream :licking: These are typically older and less energy efficient models that could probably be replaced by a newer, small, more energy efficient model (see #1).
   / Saving electricity #16
A good investment is a programmable HVAC thermostat. The house the way you want it when occupied, cut it back when not there. If your HVAC is over twenty years old, upgrading that would make a major reduction dent in that ever escalating utility bill.
   / Saving electricity #17
You aren't going to beat the power companies;ours just got a rate increase because there wasn't enough power used because of the easy winter!We have done all the power saving that we can and our bill is still $100+ a month,and no electric heat.
   / Saving electricity #18
Energy conservation is simple. You get out of it what you put into it. No you can't beat the electric company but there is enough technology out there to save a bunch of money without having to switch to Gieco.
Hey, thanks all, for the great comments.
We are pretty careful already here, about 10 kwh/day here, outside of AC season.
I started this thread because I'm always looking for efficiency gains that I hadn't thought of, and to help other folks by sharing ideas.
Our place is heated by Natural Gas, as is our hot water. AC is an older unit, but reasonably efficient, and we tend to not use it except for really scorching days. The Smart (Utility) Meter forced on us means that we are on Time of Day billing, and we do shift as much as possible to low rate hours.
I also use a whole house B+D meter, to track overall use. This meter does not have the resolution of a Kill A Watt meter, but does a good job of checking monthly useage, and works as a reminder if I've left a heat lamp going in the garage or some other higher wattage item. It does have a Null (Tare) function that you can use to zero out a constant running item, so that you can measure something else (or, just do the math yourself - the resolution on this means you really need another meter if you are trying to count individual watts).
Couldn't find the meter on the B&D site, so here is a Amazon listing:
[ame=http://www.amazon.com/Black-Decker-EM100B-Energy-Monitor/dp/B001ELJKLE/ref=sr_1_1?ie=UTF8&qid=1335905962&sr=8-1]Amazon.com: Black & Decker EM100B Energy Saver Series Power Monitor: Home Improvement[/ame]
EM100B is the model #, if the link does not work out.
I like the gravity drain sump idea, our first house (backed onto a ravine) had that, but that solution is now likely specifically banned in Canada (our gubmints are hard at work trying to figure out how to tax gravity, but haven't quite figured it out yet :confused2: ). Worked great in our house, but the contractor goofed on the house next door - he left the loose O pipe too long at the outlet into the ravine and it lifted up and froze in the winter.
Based on the number of ground mount solar arrays I see, I suspect the farmers in our area already have MicroFit fully booked (good for them, I'm glad to see the revenue going their way). I'm not really looking to do a major Alt Nrg installation on this property, I'm more inclined to do that on a remote retirement property. At this point, I'm leaning towards being totally off grid, esp. if I continue to live in Ontario.
Newer appliances.... hmmmm.... not always so straight forward, (total) cost wise. Newer refrigerators (until you get into really high end ones), tend to have smaller hp compressors running at higher rpm and use thinner wall coils - translation - many of these newer fridges burn out in < 5 years. If you need/want to make the jump, talk with an appliance repair guy that has been at it 10+ years, for a recommendation. Eventually, I want to make the move to a Sunfrost fridge, they seem to balance energy with lifespan pretty well.
Refrigerators, home compost bins and sustainable living products - Sun Frost
Sunfrost developed their original units to safely store medicines and vaccines in remote parts of the world, VERY off grid. In the original design, efficiency was a priority, as was long life.... the nearest repairman would often be hours or days away (by plane). I'm hoping the legacy lives on long enough for me to buy a unit for my next house. DC is an option for their units.
Picked up a Sylvania LED strip recently ($16) - not bad output for 1.0 watts, but strangely the light pattern is at 90 degrees to the strip - not what I expected, but not a deal killer for me.
[ame=http://www.amazon.com/Sylvania-Under-Counter-Linkable-Strip/dp/B000IV5PB0/ref=sr_1_8?ie=UTF8&qid=1335907195&sr=8-8]Amazon.com: Sylvania Under Counter 9" Led Linkable Strip Light White: Home Improvement[/ame]
Sylvania product # LED/UC/W/9/W
Sorry, not trying to make this an Amazon ad, honest, but couldn't find the LED strip on the Sylvania site.
Keep 'em coming guys, we all could use to save a little more !
Rgds, Dave.
   / Saving electricity #20
as less electricity is used, be prepaired for the rates to increase. Gas prices increase as gas use decreases because the production companies need the revenue to operate.
weve done the florescent lamps, setback thermostats, light timers so exterior lights shut off at 10pm, etc.
but our bills dont seem to decrease any.
ID LIKE to switch to led lighting, but the savings in electrical cost will never pay for the cost of the lamps. I checked into swapping out my 11 watt and 20 watt landscape lights to LED.... but it would take me aprox 20 years to recoup the cost. maybe after the cost of lamps go down ill do it.
also, i really agree on the refrig & freezer taking most of the power. A new refer will use drastically less electric than old ones.
I had a client that had a real old refer with a built in beer tap. I put a meter on it and it was accounting to nearly 25% of his power bill
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2016 CAT RM300 (A50854)
2016 CAT RM300...
Toro Workman Cart (A50322)
Toro Workman Cart...
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
Super Material Lift MH1000 (A51039)
Super Material...
