Saving A Ford 3910
/ Saving A Ford 3910 #1
PM Wells
Foothills Of The Blue Ridge NC
98 New Holland 3930-- 95 Massey Ferguson mf 253
About a month ago I traded for a Ford 3910 tractor that had stopped running. The young man that owned it said he was doing some light grading with a box blade and it just stopped running, and after he tinkered with it over about a month off and on, he decided it must be the injection pump. I don't think he had owned it very long. I decided to take a chance on it. So far I have found that the tractor had not been maintained very well over the years. I drained the old fuel and cleaned the tank, replaced the fuel filter, poured in about 5 gal of new fuel. I had fuel everywhere at the pump, but would not get to the injectors. After some discussion with others familiar with Ford diesel tractors, I decided to send the pump for rebuild. I am hoping to get the tractor running to see what overall condition it is in. Hoping for the best.
I probably should have sent the injectors too, and may still have to have them checked. Since I was getting no fuel to the injectors, I thought I would get the pump rebuilt and go from there. The pump guy has told me that the metering valve was stuck. I have no idea what condition the engine is in, except it turns over good, and the tractor has no leaks that I can see, except a minor leak around the left rear hub. the pump had been leaking, other than that the tractor is dry, and looks to be in good original condition, with faded paint and surface rust on the hood. Oil in transmission looks milky, so it probably has water in it. Fuel looked a little cloudy, must have sat for a while.
/ Saving A Ford 3910 #4
No more than it costs to test good injectors it is good practice to have them checked when pump work is done, especially when fixing a new-to-the-owner machine. Catching a functional injector with a poor pattern may save a piston and engine overhaul.
Thanks for the advice, I certainly do not want an engine rebuild, that would put this tractor into the salvage category for sure.
/ Saving A Ford 3910 #7
Shoulda sent it to me..
Having your pump looked at & not sending the injectors, is like taking a bath & putting on dirty sox..
Its dam near impossible for a running pump/engine to have a stuck MV.. {just so u know}
The MV is supposed to move back & forth.. & if its stuck,{something u coulda fixed} what do u think has happened to the injectors.??
1 more thing, then I'm done "yelling" at u.. Lol.. Once the pump gets to pumping & sends fuel to the injectors.. if the injectors or even just 1 is stuck closed, it'll seize the pump & your stuck w a 750.00 boat anchor or door stopper..{however much they charged u to o/h your pump}
You know I think I may know you from a few years back, did you have a Ford 260C trencher tractor for sale? if so I thought about buying it. Now getting back to the injectors, it could very well be an injector problem, I could not get fuel up to the injectors before I took the pump off. I know little to nothing about this tractor, just feeling my way along at this point, I guess I like to take chances
/ Saving A Ford 3910 #9
Why don't you just take the injectors in for test/rebuild NOW!
BEFORE...... you put the pump back on!
That 3910 is a nice old tractor.
I would like to have one.
Good advice, I have been checking on new injectors today. I noticed a lot of carbon buildup on the flap on top of the muffler, it makes me think the tractor was not running right. I watched a few videos on youtube that seems to point to the injectors as a possible problem also. Along with what thepumpguysc said, I am sure I will at least have the injectors checked before the pump is reinstalled or I try to crank. Thanks for all the good advice.
Took the injectors out today, and they all look really bad. Soaking them to try to clean up before I have them checked.
Just by looking at them I don't see how any fuel came through the nozzles, course under almost 3000 psi of pressure some
could get through, I suppose. I am almost certain this tractor did not run very good. Since I have a pig in a poke so to speak,
I am wondering what shape it will be in with new injectors and rebuilt pump.
/ Saving A Ford 3910 #12
With the injectors out a compression test is easy and the next logical step.
I would like to know how the compression is in each cylinder, but with the pump off wouldn't I throw the timing off if I turned the engine over?
/ Saving A Ford 3910 #14
The pump only goes on the gear one way. But having the gear attached to the pump would be more prudent than spinning the engine with the gear loose. There isn’t room under the timing cover for the gear to jump time but if it were to bind against the cover it could end badly. You could round up a tester and suitable adapter and run the test after mounting the pump.
That sounds reasonable to mount the pump and check compression. Would it be a good idea to get a little fuel into the pump first, to keep from spinning it while it is dry? I do not want to damage the pump.
Rick, looks like you have way more experience on these Ford diesel engines than I do. I have a question about mounting the pump,
I know the pump has a slot that is supposed to receive the dowel in the drive gear, and the pump base has slotted holes to attach the pump to the engine, and a mark that was set to "0". My question, Do I mount the pump loosely so I can align the gear to the pump to make sure it is not meshed too tight with the other timing gears before I tighten everything down?
Also do you know of a source to get the compression tester I need without all the other adapters that I will never use?
/ Saving A Ford 3910 #18
Mount the pump to the gear finger tight. Mount the pump to the adapter plate aligning the index mark with the zero hash. Tighten the pump mount hardware then the hardware fixing the gear to the pump. The gears will be aligned. See if any local auto parts stores will rent/loan (with a deposit) a suitable tester. Some do that with automotive specialty tools, you might get lucky with a diesel test kit. Beyond that, I’d look at eBay or similar sources.
Thanks for the advice on mounting the pump, and I will look around for the compression adapter I need for the Ford 3 cylinder diesel. I would just buy the set, but I know I will not need the adapters for cars and trucks.
I did notice that the transmission fluid was milky looking, so that means water is in it, probably from sitting outside a lot in the weather, that means new fluid and filter, and also engine oil and filter change. Well like I said I am trying to save this Ford 3910 from the salvage yard. Maybe I can figure out how to post a few pics soon.
2019 Dodge Durango SUV (A66738)
2019 Dodge Durango...
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
2011 CATERPILLAR 279C SKID STEER (A65056)
2011 CATERPILLAR...
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
2022 PETERBILT 389 (A67714)
2022 PETERBILT 389...
PORTA POTTY (A67714)
