Saved by a steering wheel
/ Saved by a steering wheel #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
I was pushing a downed tree with my grapple when it snapped back. The only thing that save me was it was stopped by the steering wheel
Lesson learned
/ Saved by a steering wheel #2
They can really get away from you in a hurry. Every time I don't treat them with respect, they about knock me off the tractor, or puncture some 1k item
/ Saved by a steering wheel #3
Glad your ok!! Safety First!
/ Saved by a steering wheel #5
Dang!
Maybe pickup a lotto ticket or 2... ?
/ Saved by a steering wheel #6
Glad you're ok. It sure makes me appreciate the mid mounted ROPS on my tractor even more.
/ Saved by a steering wheel #7
Glad you are ok and that is a good reminder to the rest of us.
/ Saved by a steering wheel #8
Thanks for all the comments. Yes I was lucky. 50 plus years tractor experience and yes it was close
No more pushing big trees
I had no idea it was spring loaded
Andy
/ Saved by a steering wheel #12
:eek: glad your okay...whew.
/ Saved by a steering wheel #13
Take the rest of the day off.
Exactly. Step back and think about it. Every time that I do something stupid is because I was tired, hurrying, or hurrying and tired.
To the OP; glad that you are OK. 👍 Your post is a timely reminder that accidents don’t just happen to novices.
/ Saved by a steering wheel #14
Like the others I'm glad you are OK. What did it do - pop up over your closed grapple ?? Those things happen so fast that it's not scary until after it's over and you realize what could have happened.
gg
/ Saved by a steering wheel #16
Count your blessings. Thanks for sharing. Experience helps us all.
Like 4 or 6 post ROPS on tractors handling trees for that very reason. Still have to be careful.
/ Saved by a steering wheel #17
Firstly, I'm glad that the OP is OK. Thanks for posting.
I know that it's 'hindsight' however, I try to use the "measure twice, cut once" principle... in other words, look at the problem/procedure and figure out what 'could' happen.
/ Saved by a steering wheel #18
Glad you weren't hurt. That's dangerous work
So many injuries - some fatalities - here (SE OH) from moving downed trees that snap back; or cause a branch to fall.
I try to do it only w/ my TROPS machine but sometimes you need to get a job done ...
/ Saved by a steering wheel #19
Lesson learned
View attachment 748655View attachment 748656View attachment 748657
I don't use a grapple, (my backhoe with hydraulic thumb suffices as a mini-grapple, as long as the load is well balanced), so this post was very educational for me.
I extend the sentiments of others: glad you're OK. I do know this kind of stuff happens real fast. And yeah: it's scary afterwards - if you're still conscious...
/ Saved by a steering wheel #20
Glad you are OK.
We had one of those tornadoes go through here that never touched down, snapped 130-40 ft tall pine trees off about 10’ above the ground on our tree farm. Looked like pickup sticks, about 200 trees. That was one of the most dangerous things I have ever seen, to try to handle with a tractor. Acres covered with dead fall and spring loaded traps. Look every situation with downed or dead trees over very carefully. Glad you shared
