Saved by a steering wheel
/ Saved by a steering wheel #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
I was pushing a downed tree with my grapple when it snapped back. The only thing that save me was it was stopped by the steering wheel
Lesson learned
/ Saved by a steering wheel #2
They can really get away from you in a hurry. Every time I don't treat them with respect, they about knock me off the tractor, or puncture some 1k item
/ Saved by a steering wheel #3
Glad your ok!! Safety First!
/ Saved by a steering wheel #5
Dang!
Maybe pickup a lotto ticket or 2... ?
/ Saved by a steering wheel #6
Glad you're ok. It sure makes me appreciate the mid mounted ROPS on my tractor even more.
/ Saved by a steering wheel #7
Glad you are ok and that is a good reminder to the rest of us.
/ Saved by a steering wheel #8
Thanks for all the comments. Yes I was lucky. 50 plus years tractor experience and yes it was close
No more pushing big trees
I had no idea it was spring loaded
Andy
/ Saved by a steering wheel #12
:eek: glad your okay...whew.
/ Saved by a steering wheel #13
Take the rest of the day off.
Exactly. Step back and think about it. Every time that I do something stupid is because I was tired, hurrying, or hurrying and tired.
To the OP; glad that you are OK. 👍 Your post is a timely reminder that accidents don’t just happen to novices.
/ Saved by a steering wheel #14
Like the others I'm glad you are OK. What did it do - pop up over your closed grapple ?? Those things happen so fast that it's not scary until after it's over and you realize what could have happened.
gg
/ Saved by a steering wheel #16
Count your blessings. Thanks for sharing. Experience helps us all.
Like 4 or 6 post ROPS on tractors handling trees for that very reason. Still have to be careful.
/ Saved by a steering wheel #17
Firstly, I'm glad that the OP is OK. Thanks for posting.
I know that it's 'hindsight' however, I try to use the "measure twice, cut once" principle... in other words, look at the problem/procedure and figure out what 'could' happen.
/ Saved by a steering wheel #18
Glad you weren't hurt. That's dangerous work
So many injuries - some fatalities - here (SE OH) from moving downed trees that snap back; or cause a branch to fall.
I try to do it only w/ my TROPS machine but sometimes you need to get a job done ...
/ Saved by a steering wheel #19
Lesson learned
View attachment 748655View attachment 748656View attachment 748657
I don't use a grapple, (my backhoe with hydraulic thumb suffices as a mini-grapple, as long as the load is well balanced), so this post was very educational for me.
I extend the sentiments of others: glad you're OK. I do know this kind of stuff happens real fast. And yeah: it's scary afterwards - if you're still conscious...
/ Saved by a steering wheel #20
Glad you are OK.
We had one of those tornadoes go through here that never touched down, snapped 130-40 ft tall pine trees off about 10’ above the ground on our tree farm. Looked like pickup sticks, about 200 trees. That was one of the most dangerous things I have ever seen, to try to handle with a tractor. Acres covered with dead fall and spring loaded traps. Look every situation with downed or dead trees over very carefully. Glad you shared
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
