Satoh S650G tractor
/ Satoh S650G tractor
Oh,,,,,,Grieg,,,,,,after talking with BILL from VALLEY POWER,,,,it DOES NOT have left-handed threads,,,I thought about that also till I talked to Bill
Semper-Fi
/ Satoh S650G tractor #42
Sorry to hear you're still having trouble.
I would keep hammering with the impact wrench for awhile longer. Try short bursts to maximize the effect (especially if you are using a small compressor and a long length of hose). If you use a cheater pipe and wrench you run the risk of twisting something or rounding off the head.
If it was my tractor, I would consider cleaning it in place. Use diesel fuel to scrub the whole reservoir and screen. Once it's all squeaky clean, fill it with hydraulic oil and see if your lift is working properly. Since the screen has holes in it, there should be no flow restriction. If the lift still is not working right, then you have problems elsewhere. My first thought then would be, "where did those pieces of the screen go?". If they passed thru the pump, they may have damaged it. They could have ended up in the valve body causing anything from scoring to stuck relief valves.
In an earlier post you mentioned that the lift went higher than ever before. How high did they go? Measure from the ground to the bottom of the lower lift arms and report back. Even though they would lift, did they have any power (ie..could you stand on the drawbar and it would still pick you up?)
I'm trying to narrow some things down to see if the problem is:
1) Low Volumetric efficiency in the pump
2)Low system pressure
3)Flow obstructions
4)Mechanical failures (lift cylinder, valve body, relief valves, etc)
/ Satoh S650G tractor #43
If you use the wrench, get a hammer and smack it on the head while putting pressure on it.
B/8
Cant do ANYTHING with this anymore due to I now have it COMPLETELY disassembled all the way down to an empty resivor box and awaiting bunches of new parts from Bill at Valley Power. BUT,,,,I am having TWO new problems while waiting all new parts. One is,,Bill says he DOESNT have a filter for this tractor since MINE measures ONE inch in diameter and FIVE & 3/4 inches in length. and TWO,,,my OUTSIDE collars that bolt onto the outside of the box with 3 bolts which the shaft passes through are WORN a LOT,,,Tried taking them to my local machinist to have bushings made for it and OMG,,,,they want 300.00 per side to make a bushing and Bill from Valley power wants 150.00 a piece for new ones. ALREADY spent a FORTUNE through Valley Power on ALL the other parts we ordered and we are strapped for now. Any suggestions on how to make collars or bushings besides a machinist and 300.00 per side????? And ANYONE have a filter for this tractor in good condition and HOW much for one my size,,,One inch in diameter and 5 & 3/4 inches long and a NUT to REPLACE the one I finally got out but is now messed up?????? thanks you guys,,,,You are the best
Semper-Fi
Devil-Dog
/ Satoh S650G tractor #45
You might talk to the shop instructor at a local high school or Vocational college and see if they need a project for a student. They might only want materials paid for.
As far as the filter - what was the old one made of? Is it a cylindrical frame with a fine mesh screen soldered over it? Can you figure out what mesh size it is?
/ Satoh S650G tractor #46
Does the wear on the collars affect anything. Will it make it leak or anything? If not, I wouldn't worry about it. 3pt hitches tend to be pretty sloppy anyways.
On the other hand, if it's going to cause you problems....then post the exact dimensions of the collars (try to use calipers for the measuremnts). I'll see if I can think of a workable replacement.
As for that pesky filter.....just leave it off. I've logged 450 trouble free hours since removing mine. I just replace the fluid once a year (it only holds a gallon and it's cheap insurance).
Yes it is B/8
The cylinder is in EXCELLENT shape and yes,,,,its the wire mesh that has three holes about the size of a number two pencil in it,,,,If I knew what size and type of wire mesh,,,I can REMOVE the OLD wire and Re-Attach NEW wire to it and fix it. As soon as Bill ships ALL my parts,,,Im EXCITED about putting it ALL back together and seeing it run again WITHOUT any leaks whatsoever on the Resivore Box.,,,Then if it STILL WONT lift ALL the way,,,,theres ONLY ONE thing left,,,,,The PUMP ITSELF,,,,GOD Im hoping its NOT the pump after replacing ALL these parts,,,Awaiting your reply my friend & STILL awaiting parts from Bill
Semper-Fi
Devil-Dog
Opps B/8
YES,,,I was POURING oil out of the collars the old way,,,,Found a machinist today whos going to make me TWO NEW bushings for the old collars so as when I put the NEW sleeves or bushings in the OLD collars,,,,It will ALL be nice and SNUG again without ANY slop whatsovever....Still awaiting parts from Bill,,,,Been a week since we ordered and Bill is still rounding up ALL the parts. So now Ill just remove the OLD wire mesh and run it WITHOUT the screen as you suggested and change the oil yearly,,,,,thanks B/8,,,You the MAN
Semper-Fi
Devil-Dog
/ Satoh S650G tractor #50
I just got a Mitsubishi S-650G and There is a problem with the gas so my question is there a screen somewheres to clean. The carb just got a new kit. Someone please respond, Thanks
Ok,,,,I know ALL you WONDERFUL People who have HELPED me out over the last few months thought I fell OFF the planet but I am Back. I had surgery that had me laid up for 6 weeks and I had to recoup from that but ANYWAY,,,,Starting from Bill from Valley Power ALL the way down to B/8,,,Oliver and ANYONE I missed,,,,Installed New T-stat housing,,New Water pump and a TON of EVERY Part in the Hydraulics Resivour,,,,COMPLETE 100 % SUCCESS...For the First time since We had this Tractor the 3 point hitch RAISES UP 100% and LOWERS 100% and works like a BRAND NEW SYSTEM...We are TICKLED PINK and NOT ONE Single LEAK ANYWHERE,,,,I thank ALL YOu guys from the BOTTOM of my HEART Because I Could Not have done ANY of this WITHOUT your HELP and Im NOT a Machanic but You guys gave me KNOWLEDGE where I had NONE on this type of problem....GOD BLESS ALL you Guys and GOD BLESS Tractors By Net...You guys ROCK....Forever GRATEFULL and Semper-Fi
/ Satoh S650G tractor #53
bbsr I have a Satoh tractor S-650G ser.#S-650G-001074 what year is it anyboby
/ Satoh S650G tractor #54
There is, as far as I know, no vin# dating on a Satoh's. So my guess on yours with such a low serial # of- 001074 is a 73-74 model. Mine is a 76 @ # 004338
/ Satoh S650G tractor #55
to Devil dog Who is the Bill you referred to regarding a thermostat housing? I need to order one for my tractor Thanks
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
We do NOT accept credit cards as payment. (A64127)
We do NOT accept...
